70-71-72 grill
Old Dec 12, 2009 | 08:08 PM
gangstakr's Avatar
gangstakr
70-71-72 grill
Does anyone have a source to get the correct plastic nuts for the 70-71-72 grills? Needed are the four per side headlight bezel nuts. I know two are long and two are short. Then the four per side grill inserts for the 70. Then the six per side 71-72 short ones I believe. I have grill nuts that fit in 1/4" square holes but their the flat ones.
I would like to buy in quantity. Any help appreciated.
Old Dec 12, 2009 | 09:33 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
How many dozens would you like?
Needed are the four per side headlight bezel nuts. I know two are long (380442S) and two are short (382735S).
Then the six per side 71-72 short ones I believe (383356S) How many dozens of these would you like?
Cannot help you with 1970 grille insert nuts, because the part numbers aren't listed.
1970: There were two different types of grille inserts and two different types of grille shells.
Before serial number J30,001 there are right & left grille inserts, one specific grille shell for these inserts.
From serial number J30,001, the two grille inserts are the same right & left, the shell was modified so these inserts would fit.
380442S & 382735S are both obsolete, but I found 100's, many right here in LA LA Land.
383356S has been replaced by N806334S and is available from FTE sponsor PARTSGUYED.COM @ 37 cents each. MSRP is $0.63 each.
I have the current Au-Ve-Co Products Catalog: 353356S is available from them in a pkg of 25. The other two p/n's are no longer available.
Old Dec 13, 2009 | 03:29 PM
BobbyFord's Avatar
BobbyFord
Dennis Carpenter has the headlamp bezel nuts.
Old Dec 14, 2009 | 02:17 AM
NumberDummy
They must be repops, as they are not listed on DC's NOS parts website.
In case DC doesn't have any...here are some sources that have the largest quantity.
380442S .. Headlamp Door Screw to Grille Shell Plastic Nut-Long / Obsolete
NORTZ & VIRKLER FORD in Lowville NY has 23 = 315-376-6594.
FREESE MOTORS in Monticello IA has 33 = 319-465-3541.
GREEN SALES CO. in Cincinnati OH has 42 = 800-543-4959.
382735S .. Headlamp Door Screw to Grille Shell Plastic Nut-Short / Obsolete
LYLE'S FORD-MERCURY in Eagle Grove IA has 24 = 800-397-6319.
BI-STATE FORD TRUCK in Toledo OH has 45 = 419-729-5141.
NORTZ & VIRKLER FORD has 66.
GREEN SALES CO. has 183.
flatheadjohn
20
Apr 22, 2017 09:54 AM
NCMillwright
2009 - 2014 F150
Apr 19, 2016 10:36 PM
ford4x4nut
Jul 10, 2013 05:48 PM
zakt
Oct 11, 2008 10:16 PM
ha2400
Paint & Bodywork
Jun 11, 2005 09:11 PM
