Frame Swap Question
Old Dec 12, 2009 | 06:18 PM
BSCowboy's Avatar
BSCowboy
Frame Swap Question
I've got a 75 F-150 with a bent front cross member. I found a 76 F-100 super cheap and was wondering if they are both long wheelbase trucks can I swap the frames out? Or, would it be easier to take mine to a frame shop and get it straightened?
Old Dec 12, 2009 | 07:41 PM
fellro86's Avatar
fellro86
They should be a bolt and go operation.
Old Dec 12, 2009 | 07:46 PM
BSCowboy's Avatar
BSCowboy
Thanks for responding, I was getting worried.
Bolt and go, that's refreshing, but I would need to use my F-150's suspension right? Also, is the straightening out of the question?
Old Dec 12, 2009 | 07:49 PM
fellro86's Avatar
fellro86
The trick to straightening is that they typically are never fully true again, so it depends on how the frame is damaged. The suspension is similar, and the brakes are the same if I recall properly, it was into the 80's that they made the changes between them. The F150 was more of a way to get out of some emissions rules if what I have heard is correct.
Old Dec 13, 2009 | 08:34 PM
BSCowboy's Avatar
BSCowboy
Thanks for the help. I am going to take it by a fameshop and see how bad they think it is before I purchase another truck and attempt the frame swap.
Old Dec 14, 2009 | 08:59 AM
Blackfoot Big Block's Avatar
Blackfoot Big Block
I agree with fellro86.
Once a frame is bent I think it's darn near impossible to get it perfect. If your frame is not bent too badly I think it shouldn't be too expensive to get it "straightened".
I've never had the discipline to just do a frame swap (or cab/bed/body swap). Every time I've done this so far, the scope of the project grows. It's the "Well as long as it's apart, why don't I [insert repair/upgrade of your choice] syndrome. In theory, it shouldn't be that big a job; if you are disciplined about it.
Old Dec 14, 2009 | 04:59 PM
BSCowboy's Avatar
BSCowboy
That's too funny, I have already been thinking of all the "other" things I can do while I am doing the swap, that's why I am going to take it by a frameshop first. It's not a bad dent in the front crossmember, like someone hit a rather large rock or something. Enough to bend it back slightly and twist the engine a few degrees off center.
Again, thanks for the input.
Old Dec 19, 2009 | 12:29 AM
RA051126's Avatar
RA051126
Banned
The f100 and f150 are identical as well as the suspensions,also everything is interchangable......ditch the damaged frame and go with the f100 frame......for all intents and purposes its the same.....
Old Dec 19, 2009 | 07:21 AM
BSCowboy's Avatar
BSCowboy
thanks, I appreciate the information. Frame swap it is, when I find the time.
Hunter2506
Mar 23, 2015 11:20 PM
el_borracho
Jul 2, 2013 10:38 AM
cars2cool
Nov 17, 2010 09:15 AM
vadim p soroka
2004 - 2008 F150
Oct 15, 2010 10:27 AM
grace553
Jun 27, 2007 01:43 PM
