Offroad & 4x4
Trac Bar Removal
Old Dec 12, 2009 | 12:32 AM
Prozon's Avatar
Prozon
Trac Bar Removal
So awhile back Ed told me that my truck flex's so poorly because of my short trac bar.
What would it take to be able to remove the trac bar? I heard I would have to have more leafs in the pack. How many minimum to make it good...? Or what would I need to do.. With the stock springs, there is no way to remove the trac bar and have it drive safely.. but I figured I would ask because the front springs will have more to them now with the lifting and what not.
Thanks in advance.
Old Dec 12, 2009 | 02:33 AM
75F350's Avatar
75F350
Major requirement is the shackle reversal. The front swing shackle is probably the biggest reason why the trac bar is required. I have run the front swing shackle without a trac bar with limited success, but the odds greatly increased when the shackle was placed at the rear of the front spring.
Both of my recent Bronco builds are running bone stock front springs with no trac bar.
Here is the one that went together over the Holiday weekend:
Old Dec 12, 2009 | 02:34 AM
SOB Racing's Avatar
SOB Racing
trac bar and safe driving go hand and hand. are u sure u are not talking about sway bar. figure it out because u can operate semi safely w/o sway on the other hand the trac bar removal could put u in a very uncomfortable place if u plan on driving faster than u can run.
Old Dec 12, 2009 | 10:01 AM
75F350's Avatar
75F350
Broncos with stock F350 leaf sprngs, shackle reversal, and no "Trac bar" commonly run 80 plus miles per hour on the freway with zero issues.
Matter of fact, the black one with Super Duty front leafs does this on a regular basis.
Notice no trac bar here:
Sway bars have also been ditched. Those limit flex like crazy, and are rather useless for lifted rigs that require some articulation.
No sway bars, and no trac bars. Thats part of the key to leaf springs and decent flex:
Stock front springs and no trac bar:
Old Dec 12, 2009 | 02:00 PM
Prozon's Avatar
Prozon
So your saying with just the shackle reversal I should be okay?
I've done the shackle reversal in the front and shackle flip in the rear. I've also added leafs up front, a custom leaf pack of sorts. Not what I had planned on in the beginning, but it will do until I get the new lift springs. I'm aiming for Feburary or sooner. I wish I had more money to throw at the F-350 lol.
So with the shackle reversal I should be able to take my trac bar off.. what about the sway bar? I never put ANY thought into this. Would it hurt its pavement capabilites? I still need it to be safe to drive to any spots. Its not a trailer queen yet..
Old Dec 12, 2009 | 02:43 PM
captain p4's Avatar
captain p4
Ed drives his trucks on the street all the time as far as I know without sway bars.
I drive my bronco on the street a good bit without sway bars.
If you're worried about it or don't like the way it handles without them you can get sway bar disconnects which is like a quick disconnect for when you get to the offroad spot, then hook them back up when you're done wheelin.
It's not unsafe by any means, but be prepared for it to handle differently. I didn't notice any appreciable difference, but it may vary for your truck.
Old Dec 12, 2009 | 06:26 PM
Prozon's Avatar
Prozon
I'm too lazy to have sway bar disconnects. If I take it off, its staying off lol.
Thats another thing I never understood about people who have mud tires and street tires. Unless you plan some HUGE trips or something, I wouldn't ever do it. I usually go four-wheeling on a whim, I dont want to have to swap tires everytime I go.
But as a last minute change of plans (welder stopped working) I havn't done the shackle reversal. Pulled the crap I had and just threw the leafs back on. It is higher in the front, but not nearly as much as I wanted. I'll get the welder going again and finish my front's hangers.
Old Dec 12, 2009 | 07:11 PM
Truckin4life's Avatar
Truckin4life
Street Queen to the extr3m3
Ed: I really dislike you, i haven't seen a single vehicle you own that i dont want!
Old Dec 12, 2009 | 09:11 PM
79Ford4x4's Avatar
79Ford4x4
I'd ditch the sway bar all together. None of my rigs have or will have them. What happened with the welder? And where are the picts
Old Dec 12, 2009 | 11:38 PM
Prozon's Avatar
Prozon
The welder stopped... welding. Lol. I can't get it to do anything at all.
I'll figure it out later. The truck is a few inches higher in the front. And.... the rear is higher than the front. I need to get that reversal set up. I'll finish the hangers soon and bolt it all on.
You'll get pictures soon enough.
Old Dec 12, 2009 | 11:40 PM
Truckin4life
Bad connection or a blown fuse maybe, on the welder that is.
Old Dec 13, 2009 | 12:16 AM
Prozon's Avatar
Prozon
It started working again...
I don't understand what went wrong..
I guess i'll finish up the hangers and bolt em on soon...
Anyone know what would cause a welder to stop putting out electricity and then mysteriously just start again??
Old Dec 13, 2009 | 12:33 AM
captain p4's Avatar
captain p4
bad ground
Old Dec 13, 2009 | 01:20 AM
79Ford4x4's Avatar
79Ford4x4
Yeah a bad ground will make it act like that. Make sure the cable is tight with the clamp. Also, the copper polarity strips inside the welder get corrosion on them. Was it still spooling out the wire or nothing at all
Old Dec 13, 2009 | 03:01 AM
Prozon's Avatar
Prozon
I have a Lincoln ARC, the wire feed runs off of the ARC welder.
I could not get ANYTHING to work. I tried just tapping the stick to the negative cable and nothing happened. I could not get the wire to spool on the other welder, nor could I get power to a small grinder with one of the sockets.
But tried it again later and everyting worked fine.
I'll need to finish the hangers and get them on. I'm not satisfied at all with the truck's current height, and the rear is higher by a few inches. It looks really stupid lol.
