door actuators
Old Dec 11, 2009 | 08:47 PM
Joe28443's Avatar
Joe28443
Joe28443
door actuators
Has anyone replaced their faulty door actuators with ones off of ebay? I have found a seller that will sel me 5 for $85 shipped because I am buying 5. I know you can fix your own with tin foil but I am afraid I am not that smart. Thanks
Old Dec 11, 2009 | 11:26 PM
Snuffy2000's Avatar
Snuffy2000
I bought one from an eBay auction just to have in case I couldn't fix my existing actuators. I ended up installing it in the first door I took apart so I could have some time to make sure I got the fix right. In the end, I fixed four and replaced one. All work great. And I have a home-rebuilt unit waiting for the first failure.
The fix is really very easy. There is a detailed post somewhere in the archives here on FTE. Not sure you want to use foil. I think the best fix really only costs you a penny...
Steve
Old Dec 11, 2009 | 11:31 PM
Snuffy2000's Avatar
Snuffy2000
You may have already seen it but, the procedure for rebuilding the actuators is in the first post under the tech folder.
Old Dec 12, 2009 | 08:48 AM
shadows4's Avatar
shadows4
Fixing my actuators was one of the first things I had to do when I bought my Ex. It really is an easy fix. Shoot the hard part is removing the things not fixing them. Buying one and fixing the bad one sounds like a plan to me. If you didn't have the time to do them all at once you could R&R at you leisure that way! Good luck, John
Old Dec 12, 2009 | 10:35 AM
Joe28443's Avatar
Joe28443
Joe28443
thanks John, I might go out in a few and try to take one out. How much does that travel trailer weigh?? I have one too thats the reason for the X
Old Dec 13, 2009 | 11:11 AM
shadows4's Avatar
shadows4
The TT weighs 9500+lbs. I haven't really weighed it yet but I am sure its close to that. Definitely is a load going down the road.
Old Dec 13, 2009 | 11:48 PM
EXv10's Avatar
EXv10
You can do it!. I bought 2 off Ebay and then decided to do the fix after I found out they wouldn't allow the locks to be worked by hand at all. The jerk wouldn't take them back so I gladly gave them 2 bad feedbacks.
Old Dec 14, 2009 | 09:40 AM
Joe28443's Avatar
Joe28443
Joe28443
So I might not need to get them online because these are 5 @ 85 dollars. I need to go ahead and attempt it myself
Old Dec 14, 2009 | 11:08 PM
EXv10's Avatar
EXv10
That's right. I used tin foil in the connections and thay are all 5 going strong after 6 months
