Ready To Plow
Old Dec 11, 2009 | 08:20 PM
Danspeed1's Avatar
Danspeed1
Ready To Plow
My truck is back on the road, and the next storm, I am going to plow with it. I was just wondering... for those of you who plow... do you plow in 4x4 high or 4x4 low?
Dan
Old Dec 11, 2009 | 10:13 PM
Franklin2's Avatar
Franklin2
4x4 high. With the c6 I had, I would pull it down into L1 when plowing, I didn't want the transmission shifting if I happened to get fast enough. Now that I have a zf I plow in 1st gear.
Also with my 80 f150, I would set the idle speed up on the carb a little bit when plowing, and it would pick the plow up a lot better. It had the stock battery and alternator. Now I am plowing with the diesel which has two batteries, and I don't have that problem.
Old Dec 16, 2009 | 08:38 AM
mikeypmcg's Avatar
mikeypmcg
i plow in 4 low. all plow manufacturers have warnings on there plows that tell you not to exceed 5mph with the plow down, then i know i have the torque available to move mountains of snow, and most manufacturers recomend when pulling a heavy load on slippery surfaces to use low range. I figure pushing in this case is similar to pulling. In plowing my driveway it doesnt shift out of first anyway...
Old Dec 16, 2009 | 06:50 PM
bashby's Avatar
bashby
I dont have the 4wd option, ut with the C6 I usually pull it down to 1st so it doesnt shift back and forth
