Thanks for your reply. I have not had the opportunity to check any of this out. Holidays and family have me busy. I did have the windsheild replaced thinking it was the seal. The windsheild was not sealed properly. This did slow the leak some but still leaking on drivers side.
I have driven Fords all my life and this is the first problem i have ever had like this. I am like others and think Ford should step up and take care of the problem.
I have to take mine in for a cam sensor replacement so I will ask while I am there about this. I will keep you posted. Thanks for your help.
If your carpet is getting wet on the drivers side, you need to get it fixed asap. I've had the same problem with my 99 and it ruined the fuse box, and has been a nightmare of electrical problems. The water can get inside of it and it corrodes.
