Help!!
Old May 25, 2000 | 06:39 AM
Cartman's Avatar
Cartman
Help!!
OK..the 67 has some problems...
Where the firewall mounts to the frame via body mount, it's all rusted out and the cab is sagging hard and it sags so bad that it hits the steering knuckle so you cant turn...Is easily fixable?
Old May 25, 2000 | 09:52 AM
jowilker's Avatar
jowilker
Help!!
cm new cab mounts are available
Carolina Classics is one source 800-598-4211
John
jowilker
66 F100s
In the still cool hours of the night, you can hear chevys rusting away.
Old May 25, 2000 | 10:31 AM
Cartman's Avatar
Cartman
Help!!
How much are they?
The part where the cab mounts to the frame is rusted all to hell..I jacked it up and put a 2x6 piece of wood in there for temp. usage...I can get a pic of it if you want to look at it..it's pretty rusted..
And..the inner fenders are rusted out so the hood latches dont work..I hear thats pretty common with that particular body style though..thanks for your help
Old May 25, 2000 | 12:17 PM
jowilker's Avatar
jowilker
Help!!
cm my 99 cat. lists them for $90.00 a pair.
Some of these old trucks have such bad sheet metal from the salt baths in the winter, that there isn't much left to work with.
John
jowilker
66 F100s
Old May 26, 2000 | 01:38 AM
DBF's Avatar
DBF
Help!!
We have a saying, "Jack up the radiator cap and replace everything under it" Some of them develop a severe case of cancer and there's not much you can do except replace the pieces one at a time and seeing how everything is mounted to the cab, the biggest and hardest is needed first. You can put a jack under the fenders, jack them to the height needed and start welding in supports and stays to the fender and then bolt them to any holes in the frame. Sorry can't help much more then that.
Jim
Old May 26, 2000 | 04:25 AM
jowilker's Avatar
jowilker
Help!!
Redfridge
Nov 2, 2013 04:55 PM
mossyoakford96
Mar 13, 2012 12:27 PM
RawPower
Offroad & 4x4
Feb 27, 2005 05:09 PM
91fastfox
Sep 21, 2004 03:40 PM
randallc
Mar 9, 2003 12:17 PM
