Sponsored by: Kumho
front end sag
Old Sep 15, 2004 | 10:34 AM
91fastfox's Avatar
91fastfox
Question front end sag
has anyone used two way adjustable spring lox to take the sag out of the front end of their truck, if so how did they work?
'95 F150 xlt 5.8
Old Sep 15, 2004 | 10:49 AM
gatesj's Avatar
gatesj
Not really an answer, but the springs are pretty easy to replace and would fix the problem. Cheap too.
Old Sep 15, 2004 | 03:32 PM
91fastfox's Avatar
91fastfox
yeah, i priced those but 14 dollars seemed like a good deal if they worked, at least to a college student, thanks.
Old Sep 21, 2004 | 10:30 AM
TexBand's Avatar
TexBand
How do you tell if the front is sagging? On an un-lifted truck, should the front and back be level with the bed unloaded? Forgive the question, but I bought the truck very well-used, and don't know what they're "supposed" to be like.
Thanks,
Chuck
Old Sep 21, 2004 | 11:51 AM
nick88f150's Avatar
nick88f150
i thought about getting the rubber spacers for mine, im a poor college kid too. but i ended up breaking down and buying a set of springs, 120 bucks, and theyre in the mail now. ill just not spend quite so much on beer, lol.
Old Sep 21, 2004 | 12:27 PM
couleeman's Avatar
couleeman
I put in the rubber spring stops and ended up replacing the front coils a month or two later. They helped out a bit, but I would recomend spending the money and replacing the coils.
Old Sep 21, 2004 | 03:40 PM
gatesj's Avatar
gatesj
I would be cautious if you have sagging springs. I just bought a truck with sagging front springs a month ago. I could tell, not only was the front lower than the rear but the tires were kicked out at the bottom. Remember the camber changes as the spring compresses. Then I got under the truck a few days after I bought it for something else and found out that one of them had broken. It had just broken, the broken end was shiny bare steel.
If they're weak enough to sag they're weak enough to break.
With the new springs in the truck it looks normal now and the ride and handling are a lot better. It took me about two hours to put them on and I work really slow.
nick88f150: I think I spent about $70 at NAPA for a pair of the heaviest springs they had. These are OK even if I want to put a plow on. I don't know where you spent $120?!
TexBand: The front wheels should look similar to the rear and when viewed from the front be vertical. Tires that tip in toward the center of the truck on top are either set for negative camber or more likely indicate really weak springs.
7.3lpowerstroke
Oct 22, 2011 01:11 PM
ty8573
Apr 8, 2010 10:01 PM
92stx
1983 - 2012 Ranger & B-Series
Feb 10, 2006 09:31 AM
Thoth88
Jun 18, 2004 11:09 PM
black-bronco
1978 - 1996 Big Bronco
Feb 12, 2003 01:57 PM
