Window Trouble
Old Dec 11, 2009 | 07:14 AM
sjankowski's Avatar
sjankowski
Window Trouble
2000X
I,m having trouble with the drivers side window going up and down,very slow working. Could it be the motor, switch, dirty track ??
Thank you for any help
Old Dec 11, 2009 | 07:24 AM
ReAX's Avatar
ReAX
You're on the right track. I'd start by lubing up the track and regulator, because it needs to be done everyone once in a while any way. Then I would watch the voltage at the switch. It should drop as you turn the motor, I'd only expect a couple of volts, if it's dropping below say 9.5v, I'd take a look at the wire and connections, maybe even try reading the impedance. If it looks okay, I'd suspect the motor.
