460 heads
Old May 7, 2000 | 05:04 PM
mattb's Avatar
mattb
460 heads
hi i have what is probably a dumb question. i just acquired a 71 lincoln coninental 460. v.c. tags still on it. i was told it had the DOVE heads. what exactly is a dove head? what makes them special? the gy i got it from said the motor had 10.5:1 compression factory and 375 H.P. does this sound right? any help is appreciated, i am new to the 460 world, i currently run all FE's this is my first 460.
thanks
mattb
mattbalfanz@web.net
Old May 7, 2000 | 08:45 PM
RAILMAN's Avatar
RAILMAN
460 heads
MATT,
THE TERM DOVE HEADS COMES FROM THE CASTING NUMBER ON THE HEAD. THE # IS LOCATED ABOVE THE EXHAUST PORT. THE # SHOULD BE "DOVE-C" THE DOVE CASTING HAVE A SMALLER COMBUSTION CHAMBER YEILDING 10.5 TO 1. HEADS WITH A D2VE OR OTHER NUMBER ON '72 AND LATER ENGINES HAVE LARGER CHAMBERS WITH LOWER COMPRESSION AND LESS HP. YOUR ENGINE WITH DOVE HEADS HAD 375 HP ACCORDING TO ALL THE INFO I HAVE READ ON THE 385 SIERES ENGINES
Old May 8, 2000 | 08:06 PM
jowilker's Avatar
jowilker
460 heads
Old May 28, 2000 | 08:59 PM
bolo4u's Avatar
bolo4u
460 heads
Matt,
I too have an early 70's (71 I think) Lincoln dove motor (block for sure, will check heads). From what I have read, the dove block is a heavier block with longer piston skirts and thicker cylinder walls. It was designed for truck applications, thus the heavier casting. This however can be good as they can be overbored a little more than regular blocks, and are a little more heavy duty. Good luck. Mine is going to be built by a NASCAR engine bulilder to go into a '65 shortbed Custom Cab.
Don
fasttrucker01
36
Jul 22, 2024 09:42 AM
f100reborn
Mar 17, 2005 08:32 PM
cobradriver
Nov 15, 2004 12:49 PM
fordbeast_80
Apr 14, 2004 11:59 AM
jtlinn
Apr 30, 2003 07:18 AM
