Question about RABS
Old Dec 10, 2009 | 06:41 PM
johnboggs21's Avatar
johnboggs21
Question about RABS
What is the point of only having rear anti-lock brakes? I thought the whole point of ABS was so that you could steer while braking. Hard to do that when the front wheels dont have ABS, but your not supposed to pump the brakes because you have RABS?
So what am i supposed to do when braking hard and having to steer?
Old Dec 10, 2009 | 06:57 PM
FORD IDIot's Avatar
FORD IDIot
It lets them proportion the braking for a fully loaded vehicle, but keeps the rear from breaking loose when you're running empty.
Old Dec 11, 2009 | 12:37 AM
PLC7.3's Avatar
PLC7.3
4 wheel ABS allows you to steer between pulsations of the brakes.......
Our RABs system releases and reapplies rear brake line pressure only should the VSS send info to the RABs valve indicating a rear wheels lock up.....
