mods need mods?
Old Dec 10, 2009 | 06:12 PM
YoungFordAddict66's Avatar
YoungFordAddict66
mods need mods?
so i am looking at buying a full 4" exuast system from either tymar or mbrp, turbo back, soon after christmas. i like the power gains and lower egt's that i could get. after that i would like to get either the TS 6 position chip or Edge module to give me that huge hp gains. my questoin is if i do both of these what else do i need? do i need gauges, bigger injectors, a bigger turbo what? thnkas blake
Old Dec 10, 2009 | 06:39 PM
427 fordman's Avatar
427 fordman
You'll need guages to watch temps and bigger injectors to get big hp and tq gains. I just got a TS chip with PHP tunes on it and stage one DIY kit from jim at rosewood diesel. Check him out. Good prices and helpful. I've heard to stay away from edge. Intercooler would be a decent idea for you too.
Old Dec 10, 2009 | 07:12 PM
Brown Falcon's Avatar
Brown Falcon
Gauges for sure, I reccommend the PHP chip. I love mine and also got mine from Jim at Rosewood Diesel. He also does Injectors so if you want to do that down the road he's a good guy to go with. And yes, stay away from the Edge!
Upgrade the downpipe for sure with the exhaust and do a 6637 intake if you havn't already. Magnaflow makes a good 4" kit that is a bit cheaper than the others also.
Intake, exhaust, chip, gauges..... good place to start!
Old Dec 10, 2009 | 08:31 PM
YoungFordAddict66
well once i get christmas shopping done with and im done paying for my college courses im deffinatly getting a 4" exhaust with a 3" to 4" dp and yea i have the 6637 just havent put it in during this 14 degree weather. and how difficult are guages to install? i had seen that group buy and it got me thinkin about them. like a boost, fuel, egt and idk what else there is to messure maybe tranny and oil temps or pressure. what are the key guages to get that you professionals get? and whats wrong with edge chips i like the fact that you could get 100 hp and read/delete codes
Old Dec 10, 2009 | 08:39 PM
dyoung14's Avatar
dyoung14
I will tell you what we tell all the new idi guys, Gauges first! they are the most important thing so you can monitor your engine and not let things go crazy
Old Dec 10, 2009 | 10:15 PM
oldbird1965's Avatar
oldbird1965
x2 on that. Also, do the IDM mod.
Old Dec 10, 2009 | 10:47 PM
YoungFordAddict66
haha ok gauges sound i little important . and what is an idm mod?
Old Dec 10, 2009 | 11:01 PM
YoungFordAddict66
oh and what is a pyrometer gauge?what does it messure?
Oversize's Avatar
Oversize
The edge is known to mess up your PCM (engine computer) and not come completely out of it interfering w/ the sensor readings and causing drivabilty problems. The end result is usually needing to either go to the dealership, to get the computer reflashed (reprogramed) or replaced. So get a good code reader for $100-200. and then a dood custom chip from TW or PHP and they can give you a true 140 hp boost (with the right supporting mods which we can tell you how to do and arent too expensive) and youll get lot more bang for your buck. As for what you really need gauge wise youll need a Pyro, Boost, and tranny temp (if youve got an auto) other wise anything else you want to add is just bonus but youll need the pyro to monitor your EGT and boost to make sure you know what your delivering. If you want more power a set of injectors will definately do that, its just amtter of how much power you want that will determine what you need. Stage 1's are plenty for most people but 2's and 3's are available. But the higher you go the more youll need. To properly drive the bigger injectors youll need a good custom chip to run them, not to mention depening on how big you go youll need bigger oil, headstuds, eventually a bigger turbo, girdle, electric fuel, IC, a moderately sized personal loan, a third morgage, fire rings, new uppipes, new clutch or modidied auto trans, and alot of time and beer to get your friends here to come help you put it all together. The sky and your budget are the limits. But well gladly lead into the land of power, black smoke and fun, not to mention bankruptcy if you get too carried away.
Old Dec 10, 2009 | 11:05 PM
Oversize's Avatar
Oversize
Originally Posted by YoungFordAddict66
oh and what is a pyrometer?
A pyrometer is a probe that sticks in you exhaust stream and measures how hot the exhaust is getting, aka EGT or exhaust gas temperature. If you exceed 1200 for too long your piston will satrt to melt and these engines can easily generate that kind of heat so its there to help you keep from melting your motor as you turn it up.
Old Dec 10, 2009 | 11:10 PM
oldbird1965
I IDM (injector drive module) fires your injectors at 110volts stock. Change out a simple little resistor and you can get 140volts to your injectors. They will stay open a little longer helping to atomize the fuel better. Works for me.
Old Dec 10, 2009 | 11:28 PM
YoungFordAddict66
hmm well since i dont own a house mortgage's are out of the questions but i can bankrupt myself if it means i get more power and beer is a must when workin on my fords.
and thats why i couldnt find an egt gauge on clays site they are called pyrometers gotcha. and meltin pistons hu sounds seroiuos nothin a 4" exaust cant help with soon enough.
crap first you guys talk me into a 6637 kit from clay and now you talked me into gauges from him. this is a love hate relationship.
Old Dec 11, 2009 | 12:16 AM
Brown Falcon
For gauges i'd go with Boost, EGT (pyrometer), and Tranny Temp if you have a auto. Those are the most important. If you want to get all serious about it you can do High Pressure Oil, Fuel Pressure, etc but you don't really need them.
The edge chips can give a lot of power but they can also mess up your ECM and they aren't too easy on transmissions either. "Dirty Tunes" is another way I've heard it put...
Old Dec 11, 2009 | 12:19 AM
Brown Falcon
Just look at your bank account. Now just give Clay all your money... it'll be easier that way! haha!
You may lose weight because you can't buy food anymore but your truck will be nice!
Old Dec 11, 2009 | 12:23 AM
YoungFordAddict66
ok so those 3 are the main ones and the others are just extra. thanks brown falcon semper fi
