Sponsored by: Real Truck
Dashboard Help Needed.....
Old Dec 10, 2009 | 05:42 PM
jh225's Avatar
jh225
Just picked up a 2000 7.3 and as it was getting dark out, I discovered that the dashboard lights don't work.
Dome light works with the door and with the scrolling switch on the dash. (which leads me to believe that the dash is being powered as the switch dims/brightens the dash lights)
Turn signals work (light up and go off)
High beams work (blue light works as it should)
Headlight **** dot illumination works
All door switches illuminate.
ALL gauges and Idiot lights work.
Just the dashboard backround illumination and Heat/AC lights don't work.
Checked the fuses with a test light and I get no power with key off on either the 16 or 19 fuse. Pulled the fuses, both looked good, swapped to other positions with same amperage and constant hot and they work fine. Due to this, I would assume it is not the fuses.
I am wondering 2 things................
1. Can someone with the same year or fuse panel set up, take a test light to their #16 & #19 fuse with the key off and see if you get constant power there?
2. Has anyone seen this problem before and if so, what was
Old Dec 10, 2009 | 06:55 PM
ReAX's Avatar
ReAX
I did something similar, I think it's the orange wire in the HL switch controls dash illum, and I tapped it for the gauges. The buttsplice failed and did pretty much what you experience. I would pull the HL switch and look for a loose or tapped wire since it's a pretty easy thing to see.
Old Dec 10, 2009 | 08:02 PM
Rush117's Avatar
Rush117
Did you check the plug behind the dimmer rheostat?
