plug in??
Old Dec 8, 2009 | 11:14 PM
Fattyfat1's Avatar
Fattyfat1
plug in??
at what low temps do you guys/gals usually plug in your block heater? with the amount of amps it draws, just wondering when it becomes prudent. A few guys I know have theirs on a timer, but with our unusually cold temps lately, 3 hours isn't cutting it for them. factoring in oil weight, outside temps, blah blah blah. just trying to get an idea is all. thanks
Old Dec 8, 2009 | 11:19 PM
FARM69's Avatar
FARM69
I run 15W40 and no matter what temp it is 3 hours will be enough for it to start and run smooth.
I believe the engine block heater draws about 1200W an hour.
Make sure your glow plug system is operating up to par.
Old Dec 8, 2009 | 11:36 PM
MustangMatt96GT's Avatar
MustangMatt96GT
I don't.... 15w40 here and it started at -5 today... actually pretty damn well....
I want to switch to a 5w40 though.... should make it easier to start in colder weather too.
Old Dec 9, 2009 | 12:54 AM
IDMooseMan's Avatar
IDMooseMan
Our overnight low was around -5 to -8 and 'warmed' up to about -2 when I started her this morning. Started up pretty well, too. In all fairness, I did find a loose positive battery cable the other day, so I think the batteries are charging better, too after tightening the cable.
We're expecting the same temps for the overnight low, so I plugged her in just to have heat sooner.
I use a timer, too, but since I replaced the block heater, the GPs and GPR, I'm tripping the circuit breaker. I used to have the timer come on four hours before I was ready to leave and that worked out pretty good. I'm not using the timer now. If your truck is starting without any complaints, I wouldn't worry about it, otherwise, plug her in and she'll be ready the next morning.
Old Dec 9, 2009 | 07:33 AM
rideracelivemx7's Avatar
rideracelivemx7
5w-40 over here, since i bought hte truck in may, hell ive been plugging in in even when it was in the 40s andd 50s! ha but its snowing like a mother right now! easily in the high 20s, didnt plug it in and my injector seals are bad, took a good 5 trys to get it going, but it cranked over like it was 80°f outside, love that oil
Old Dec 9, 2009 | 08:05 AM
95_Dually's Avatar
95_Dually
When the temp drops below 40* I plug mine in. I like a nice warm truck on those chilly mornings.LOL
Old Dec 9, 2009 | 06:09 PM
Slimsadie's Avatar
Slimsadie
40 for me.
Old Dec 9, 2009 | 07:30 PM
Fullcrew7.3's Avatar
Fullcrew7.3
Well, it hit -35 last night. With the windchill...-45. Mind you, I took the car to work this morning, but tomorrow, I take the PSD. I plugged her in this evening. Not worth the possibility of not starting. When it hits -10, I plug in if I plan to use the truck. She may go without, but why be hard on my ol' girl.
Old Dec 9, 2009 | 09:37 PM
yoslick's Avatar
yoslick
Gets to 30 and I plug it in, only 8 miles to work and I like the heat before I get there!!
Old Dec 9, 2009 | 09:54 PM
cowmilker08's Avatar
cowmilker08
When my gp were bad, anything less than 30 F and forget it starting if I didn't plug it in.
So far now with the new gp its starts very very easy. I did plug it in tonight though. It is supposed to be 13 F in the morning and I want to be sure it would start and have heat since my thermostat is stuck open.
Old Dec 9, 2009 | 11:41 PM
Oversize's Avatar
Oversize
I usually plug it in if its going to be 40* or less. That means its plugged in all the time when Im at home or work lately. It was -17 last night -40 windchill and depending on where you are the windchill is supposed to be -50 tonight. Personally I think these temps are low enough to justify plugging it in.
Old Dec 9, 2009 | 11:43 PM
IDMooseMan's Avatar
IDMooseMan
OT...sounds like it's time for the 203* T-Stat. I'm a believer since I installed one.
Old Dec 9, 2009 | 11:57 PM
scatgo's Avatar
scatgo
-35!! -45!! Wow thats nuts. Its in the thirtys in the morning around here and I am frezzing my butt off! The next time you start your truck you might want to point it South and keep on going.
Old Dec 10, 2009 | 06:15 AM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
A quick reminder to those that plug in.
Crank your HVAC controls to DEFROST, and when the block heater is plugged in, the hot water/air in the system rises and blows across your windshield naturally and keeps it from freezing.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
Old Dec 10, 2009 | 08:33 AM
Fullcrew7.3
Good point Jim. Scatgo, I may be heading south next winter for a bit, but this is just how it goes up here. What really bites is when I have to work night shift on those nights. This coming weekend for instance.......
