problems and where to start
Make sure the line to the distributor is connected to the proper location.
When the motor is idleing is there vacuum on that hose and does it drop off when you hit the throttle?
any way yes there is some vacuum at idle. but as soon as i pulled it off i had mid throttle. i drove it like that and yeah fixed so that leads me to the conclusion that :
1 i need a new vacuum advance.
2 as i was working on it i noticed i need a new cap.
3 since i need a new cap i should replace the rotor as well.
4 while i am at it new points and condenser don't cost much.
Different versions of vacuum routing exists for different years & motors.
Check out this link and try and identify yours Ford Truck Technical Drawings and Schematics - Section I - FORDification.com
Im thinking its: Transmission Regulated Spark Control System - 8 Cyl - 360, 390 CID Engine
If yes the vacuum line from the distributor should come from the manifold not the carb.
When connected and at idle with the engine warm there should be full manifold vacuum at the distro and set the timing with the hose connected.
Then when the throttle is opened the vacuum drops and allows the distributor to advance the timing.
As I said previously there are many different setups but if the distributor vacuum is not correct it will screw up the timing bigtime.
Im thinking its: Transmission Regulated Spark Control System - 8 Cyl - 360, 390 CID Engine Those are for 1972 engines mine is a 71 also mine is a 250 not 100.
If yes the vacuum line from the distributor should come from the manifold not the carb. I haven't looked too much into where it comes from as i haven't messed with the location of the vacuum line. it is where it was since i have bought it and when it ran right.
i really operate with 3 principles
1 logic
2 planning
3 why not?/ what if.
i know some of my past comments on here got you all looking at me wierd but like i said i start off with alot of fore thought and whittle it down till it is pratical.
* and i keep her running. not turbo charged running 1/4 mile drags. not running off road and towing 300 miles up hill both ways. just running i go out turn the key and drive to work or the store do what i need to do and drive home. please note that i catch alot of flack for my views on that issue and i am not giving you attitude as fighting on the web is like yelling at the wind because you got urin on your leg when you were pissing into to it
.btw thanks for the link to all the technical drawings i have been trying to find some way to get that type of info
especially with how the lights are wired .
But....hard to troubleshoot over the net. It's just an odd thing to have happen....you disconnect something that is there for a reason, and the engine runs better..............
GM is opposite cause the distro spins clockwise and must suck the diaphram forward to advance it.
If you set the timing on a ford with the vacuum line off....when you reconnect it
it will be retarded.
I dont use a light to set timing for performance as every motor breathes different.
Some of you will say im crazy for that.
with the hose connected turn the distributor so it idles best and has decent throttle response take it for a drive ...if it pings at high rpm, you need to retard the timing a bit.
Depending if you want more bottom end performance or at high rpm you will find the sweet spot by adjusting the distributor slightly.
Always works for me.
weird this time with the hose and all. at least it started to run good enough to get back onto the original track and time table with a few added need now parts.
with in the next year i hope to be able to yank the motor out and since my goal for this truck is absolute longivaty i will be replacing every thing from the bottom up. i figgure it has lived almost 40 years and personally only cost me 3 days of work outa about 5 years of ownership. i owe it the best i can and then expect another 40 when done
.but till i get on with the rebuild i have to just keep her running. which is what she is good at doing even if she gets a little cranky some times
