Sponsored by: Real Truck
Help with Bilstein part #
Old Dec 8, 2009 | 02:27 PM
Nice Work Truck's Avatar
Nice Work Truck
I want to order some new shocks but non of the web sites have a 2007 crew cab DRW cab & chassis part #.
Are the cab & chassis the same as a DRW pickup ?
Thanks.
Old Dec 8, 2009 | 02:41 PM
Zmann's Avatar
Zmann
seems like it would't be right to put a reg shock on a truck with all that weight?
Old Dec 8, 2009 | 03:00 PM
Nice Work Truck
I have Firestone airbags in the rear also.
The truck has a daily weight or 12,000 lbs.
The HD Bilstien are supposed to be the best.
Old Dec 8, 2009 | 03:24 PM
Maxium4x4's Avatar
Maxium4x4
Moved you to SuperDuty
Old Dec 8, 2009 | 03:26 PM
Zmann's Avatar
Zmann
air bags ,, that should make all the difference !! I had bilsteins on my last one a 2500 hd with bags ,, careful the hype will exceed the actual performance IMHO
Old Dec 8, 2009 | 07:07 PM
Nice Work Truck
I have the air bags filled to 100 psi everyday and they do help a LOT.
My truck is just felling like it is bouncing and rolling more and more lately. I have about 38,000 mils on her.
Old Dec 8, 2009 | 07:23 PM
Zmann's Avatar
Zmann
I agree with you ,, since you have bags you just need some new dampning ,,
Old Dec 8, 2009 | 07:26 PM
Nice Work Truck
Yes, but I need to get the part # for a cab & chassis !
I guess I'll call Bilstein in the AM
Old Dec 8, 2009 | 10:27 PM
powerstroke72's Avatar
powerstroke72
Take a look at these Andy. The first is the rear shock and it says in the description on the right that it is for an F-350 4x4 chassis-cab with a utility body. The second is the front shock and it includes the F-350 and F-550 in the description.
Off Road Warehouse - Shocks Bilstein Shocks O.E. Applications Ford Bilstein Shocks Bilstein Shock - Rear FORD F450 SUPERDUTY 99-04 2WD 176" wheel base (15000lbs GVW), Rear FORD F550 SUPERDUTY 99-04 2WD (19000lbs GVW), Rear FORD F350 SUPERDUTY 9
Off Road Warehouse - Shocks Bilstein Shocks O.E. Applications Ford Bilstein Shocks Bilstein Shock - Front FORD F250 SUPERDUTY 05-07 4WD (Incl. FX4) (Non-Utility) , Front FORD F350 SUPERDUTY 05-07 4WD Single rear wheel (Incl. FX4) (Non-Utility), Fron
The top link shows the shock as being a replacement for the '99-'04 F-350 but on Bilstein's site, they list the same shock as a replacement for the '07 too.
Old Dec 10, 2009 | 05:13 AM
Nice Work Truck
Thanks for the links powerstroke72
I will call them when I get a chance
Old Dec 10, 2009 | 05:23 AM
Furian's Avatar
Furian
You Keep What You Kill
Shockwarehouse.com offers the Bilstein HD shocks for your application.
Front - Part # F4-BE5-C295-HO - $68.14 each (Reduced to $61.33 when added to your cart)
http://www.shockwarehouse.com/site/p...350-Superdutys
Rear - Part # F4-BE5-C296-HO - $68.14 each
Check the lower section of each webpage to verify your application. The "Set" price is $272.56 but is reduced to $258.63 when you added to your cart. You get free shipping. You can also get a 5% discount for being a FTE member using Code Ford5 at checkout.
Old Dec 10, 2009 | 06:39 AM
Nice Work Truck
Thanks for the info Furian.
Old Dec 10, 2009 | 06:42 AM
Furian's Avatar
Furian
Glad to help!
