Sponsored by: Real Truck
2008 Tail lights
Old Dec 7, 2009 | 08:49 PM
superstroker123's Avatar
superstroker123
2008 Tail lights
has anyone put the tail lights from a 2008 on a 2004 or older superduty
Old Dec 7, 2009 | 09:24 PM
Ford6.02005's Avatar
Ford6.02005
Yes-it's a very simple procedure. The taillight itself is a direct fit-the only difference is the 2008 backup light bulb uses a different plug. I have seen pigtails available from Ford to adapt the plug or you can do like I did and search your local salvage yard- I found a 2004 or newer F-150 front turn signal harness uses the same plug. Just remember the backup light is on top so be sure to cut the wires long so the harness will reach! I recommend soldering the 2 wires then shrink wrap them.
Old Dec 7, 2009 | 10:17 PM
superstroker123
okay thanks I got a set from my uncle he had to replace his bed on his 08 the new bed came with lights and bumper which he gave me for my 00
