4WD QUESTION
Old Dec 7, 2009 | 07:26 PM
jagski2's Avatar
jagski2
4WD QUESTION
I HAD MY 03 6.0 4WD ON THE LIFT TODAY- I COULD NOT TURN THE FRONT DRIVE SHAFT, HUBS WERE ON AUTO, NOT ABLE TO TURN THE SHAFT THOUGH WHEELS WERE FREE TO ROTATE. SEEMS LIKE THE TRANSFER CASE IS ENGAGED. I DROVE IT , IN AND OUT OF 4WD, HUBS LOCKED AND UNLOCKED AS THEY SHOULD, BACK ON THE LIFT IN 2WD AND STILL THE TRANSFER CASE IS ENGAGED. ANY THOUGHTS???
Old Dec 8, 2009 | 07:14 PM
topdrive's Avatar
topdrive
maybe your shift motor is burned out and it is stuck in 4x4 mine did that once pull your shift motor off and put a wrench on were the motor goes and try and turn it.It only takes a quarter turn to engage/disengage the t-case if you can turn it easily it is most likely a burnt out motor at least thats what it was in my case good luck
Old Dec 8, 2009 | 07:32 PM
jagski2's Avatar
jagski2
TOPDRIVE-THANKS FOR THE INFO- SOUNDS RIGHT BECAUSE I DO NOT HAVE 4WD LOW EITHER AND I'M ALSO OFF ABOUT 1 MPG RECENTLY. THANKS AGAIN FOR THE RESPONSE
