injectors running rich
Old Dec 7, 2009 | 06:40 PM
andrew meppen's Avatar
andrew meppen
my friend took the smog pump off of his 86 f 150 and now it fuel fouls the pluggs. ny suggestions ( i bought it for next 2 nothin) but its useless if i cnt get it runnin. if i clean the plugs it'll run about 5 min b4 the plugs foul out
Old Dec 13, 2009 | 11:33 AM
LxMan1's Avatar
LxMan1
Nothing to do with the smog pump. Either the fuel pressure regulator has failed or the MAP sensor got unplugged/ vacuum line off.
Old Dec 13, 2009 | 04:47 PM
andrew meppen
ther r 2...... 3/4" to 1" tubes comming off of the exaust manifolds and i think they may b 2 blame but i havnt gotten them plugged yet. ill try yer suggestions 4 sure though, but wat is the map sensor
Old Dec 13, 2009 | 04:57 PM
LxMan1's Avatar
LxMan1
What engine is it? Those will just cause an exhaust leak if the one way valves don't seal.
