motor casting numbers what is it?
Old Dec 6, 2009 | 05:51 PM
usmc041127's Avatar
usmc041127
I found a 351 that a guy has for sell and said it wont fit in his truck. I am wondering if it will work in my old 81 that blew up friday. The casting numbers on it are f4te-6015-aa9. He says its supose to be a 351w. Its just a long block but I am hopeing I can just get an intake for it put my assesories on it and go. Can anyone tell me if it will work or not. Thanks Mike
Old Dec 6, 2009 | 07:57 PM
AstroFab's Avatar
AstroFab
1994 351W Truck Block. It is a roller motor.
Old Dec 6, 2009 | 08:10 PM
bashby's Avatar
bashby
Post your question in Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) - Ford Truck Enthusiasts Forums and give more details like what eng you're replacing, year,... If you're replacing a non roller 351w with a roller 351w I'm sure it will work , I think with no problems but you might get a better response in the small block forum
Old Dec 6, 2009 | 10:29 PM
Franklin2's Avatar
Franklin2
If they went with a one piece rear seal on the later 351w engines like they did on the 302, you might need to get the correct flywheel or flexplate if it doesn't have one on it.
