Sponsored by: Real Truck
oil pan seal.
Old Dec 6, 2009 | 04:32 PM
WorkhorseF250's Avatar
WorkhorseF250
oil pan seal.
hey everyone just under the truck this afternoon and seen that i have a oil leak, is the oil pan seal hard to replace? i have a 2006 ford F250 5.4l 3v. 4x4. i just need to know if im able to do this.
thanks for the info and your time
Old Dec 6, 2009 | 04:34 PM
Tom's Avatar
Tom
I think it's a real bear of a job. From what I've read you actually have to lift the engine to remove the pan.
Old Dec 6, 2009 | 04:41 PM
WorkhorseF250
thats not good wow
Old Dec 6, 2009 | 04:48 PM
bill11012's Avatar
bill11012
Modular motor junkie
Do you have a hoist and have you ever pulled a 4.6 or 5.4 before? If you know what you are doing it can be pretty easy.
Old Dec 9, 2009 | 08:14 PM
WorkhorseF250
After further inspection of the leak, it is at the back of the oil pan right infront of the transmission, is there any other way of sealing this minor issue? i dont know if additives would get ride of the leak. i actually just caught the leak the day it started leaking. i want to keep the truck in good working order. any help would be great thanks
Old Dec 9, 2009 | 08:30 PM
bill11012's Avatar
bill11012
Are you sure it is the oil pan and not the rear main seal?
Old Dec 9, 2009 | 08:49 PM
WorkhorseF250
Im pretty sure, it has been dripping of the bolts on the oil pan in the back weather that indicates rear main seal or oil pan i dont know,
Old Dec 9, 2009 | 09:39 PM
bill11012's Avatar
bill11012
Have you made sure the bolts are tight?
Really the only thing you can do is drive it like that or lift the motor up to change it out.
I have a 4.6 that has the same problem and I am just driving it tell I can pull it.
