Block Heater....
Old Dec 5, 2009 | 05:00 PM
PsD007.3's Avatar
PsD007.3
Block Heater....
hey guys just wondering if i leave my truck plugged in for roughly just say 9 hrs a night, what you thinkin the electric bill will go up a month?? just needing a rough idea soo i know what to give my buddy since we split the apartment cost...what are some of the increase you guys have seen in the past...dont need any exact number just lookin for a rough idea
Old Dec 5, 2009 | 05:08 PM
Layson's Avatar
Layson
Well at a 1000 watts, it is just like running a electric heater in the house. I bet you would notice a difference..
Old Dec 5, 2009 | 05:14 PM
PsD007.3's Avatar
PsD007.3
ooo alright soo thats what the block heater pulls is 1000 watts?? i was guessing around $20 a month
Old Dec 5, 2009 | 05:16 PM
Layson's Avatar
Layson
Oh that sounds like a good number... You ought to just get a timer, some guys just have it turn on a few hours before you wake up
Old Dec 5, 2009 | 05:22 PM
PsD007.3's Avatar
PsD007.3
i'm not to worried about gettin a timer if its only $20 a month roughly i'll just keep it plugged in all night, just makes me nervous leaving my baby plugged in while i sleep
Old Dec 6, 2009 | 11:12 AM
Mike F250's Avatar
Mike F250
You would need to know what you are paying per kwh. I figured mine out two years ago at about $40 a month if I left it plugged in all the time.
Kilowatt hour - Wikipedia, the free encyclopedia
Old Dec 6, 2009 | 12:26 PM
Smokin''s Avatar
Smokin'
Smokin
Block heater = 1,000 watts
There are 1,000 watts in one kWh
So, for every 9 hours your truck is plugged in, it uses 9 kWh's. .
Look at your energy bill. Somewhere on the top they will have listed how many kWh's you have used.
Lets say they listed that you used 281 Kilowatt hours. Your total electricity charges were $50.00 So I take $50.00 and divide it by 281 to get .1779 cents per kilowatt hour. So if you're spending .1799 cents per kWh and you leave your truck plugged in for 9 hours, you use 9 kWh's, and you pay $1.62 in electricity.
So all you need to do is look at your electricity bill and find out how much you are paying for each kWh. The formula looks like this:
Total bill / your total kWh usage = what you pay per kWh.
then take what you pay per kWh x number of hours its plugged in. Then multiply that number by the number of nights you plan on plugging the truck in per month. That'll give you your monthly usage.
Old Dec 6, 2009 | 12:47 PM
ernesteugene's Avatar
ernesteugene
For the exact monthly cost first measure the Ohms resistance of the coolant heater element and assume an input voltage of 120 volts and then calculate the monthly cost from... $ per Month={(438.24)(Hours per day)($ per kWh)}/(Ohms)
For example on my Freightliner the coolant heater element measures 17 ohms and if I kept it plugged in for 9 Hours per day and I paid 0.10 $ per kWh my monthly cost would be... $ per Month={(438.24)(Hours per day)($ per kWh)}/(Ohms)={(438.24)(9)(0.10)}/(17)=$23.20!
I've got a common plug for both the coolant heater element and the oil pan heater element and since I'm a fulltime RVer I always have a "free 20A outlet" handy and I routinely plug my truck in for about an hour before starting it even for mildly cold overnight temperatures because when both the coolant and oil are warm the engine starts immediately and my AIH doesn't activate and this saves wear and tear on the AIH element and on the batteries as well as on the engine itself!
Old Dec 6, 2009 | 01:19 PM
PsD007.3's Avatar
PsD007.3
how much does a kwh hour usually run around
Old Dec 6, 2009 | 05:20 PM
farmb0y's Avatar
farmb0y
I'd save yourself the headache of all this math, go buy a $10 timer and set it for a couple hours before you normally get up. I've got just a standard indoor timer that I use everyday on my semi truck. Works great, as long as I set it to the right time.
There's no need to plug it in all night long, except to burn up your electricity. Like Gene said, on midly cold nights it may need only an hour, on nights when it's 0* around here I'll give it around 4 hours.
Old Dec 6, 2009 | 06:29 PM
stormyrider's Avatar
stormyrider
go to your local hardware store and get a timer. Set it to turn on the block heater two hours before your plan on leaving. Timer don't pull much and it will save you a lot on power bills.
Old Dec 6, 2009 | 09:41 PM
PsD007.3's Avatar
PsD007.3
ok soo if i set the timer to get on like 3 or 4 hours before i plan on getting up i would be good?
Old Dec 7, 2009 | 03:53 AM
Visseroth's Avatar
Visseroth
And make sure you put in on a very low load outlet. Meaning an outlet that has very few things on it. These things draw about 6 to 8 amps
Old Dec 7, 2009 | 10:20 AM
superduty4x4's Avatar
superduty4x4
And if you let your truck sit for 3 days without starting in single digit temps, 3 hours of block heater in the AM before you leave for work isn't enough
Old Dec 7, 2009 | 10:33 AM
Vinford's Avatar
Vinford
Plug it in around Nov.1 and dont unplug it until March 31 .(other than when driving) $100 bucks of power isnt alot compared to all the other money spent to keep these things running!
