Help needed
Old Dec 5, 2009 | 11:26 AM
johnkirk's Avatar
johnkirk
Help needed
I have a 2003 Lincoln Navigator with air suspension. Last week the rear end pumped itself all the way up. While crawling around under the rear end looking for the sensor, I noticed a mechanical lever type of device near the rear right wheel that had come disconnected from another piece of metal, & the lever was in the far up position. It's hard to explain but these 2 pieces connect with what seems to be some type of ball & socket snap together connection. I moved the lever part back to its normal more downward position & snapped the other piece back on it. The rear end returned to its normal position.
A few days later, while driving, the rear end dropped all the way. Once again I got under the vehicle only to find that the lever had once again become disconnected, this time it was in the far down position. I reconnected it again & let the system pump up the vehicle to its normal position & turned off the air suspension system & it is held air ever since.
Can someone help me identify what this lever & ball socked type of device is & what it is called? I think the connector piece of it needs to be replaced.
Thanks!
John
Old Dec 5, 2009 | 11:57 AM
bumparker's Avatar
bumparker
I don't have a Nav but in my 2003 repair manual it looks like you're describing the ride height sensor. I'll try to post some pictures.
Old Dec 5, 2009 | 12:03 PM
bumparker's Avatar
bumparker
[IMG]file:///C:/Users/Mike%20Parker/AppData/Local/Microsoft/Windows/Temporary%20Internet%20Files/OLK1B6F/s3j~us~en~filea0052318%20gif~gen~ref.jpg[/IMG]
Does it look like this, if so it is the ride height sensor.
Old Dec 5, 2009 | 01:00 PM
johnkirk's Avatar
johnkirk
Help Needed
I would take some pictures of this part but the vehicle isn't home.
Thanks for the help.
Old Dec 5, 2009 | 01:10 PM
johnkirk's Avatar
johnkirk
Help Needed
I can not open the picture. Please re-post. The linkage to the sensor is what I think I am having problems with. Is there a replacement part for the linkage?
Thanks!
Oldtrucknut7077's Avatar
Oldtrucknut7077
Check with American Air Suspension, he may have what you need.
Purchase Air Suspension Parts and Conversion Kits from THE Experts at American Air Suspension Online Store
This is where I got some parts for my Expy.
Old Dec 5, 2009 | 01:16 PM
johnkirk's Avatar
johnkirk
Help Needed
Ok. Apparently there is a TSB for this exact problem. Ford will replace the linkage with a new redesigned linkage part that will stay connected.
Old Dec 8, 2009 | 01:24 PM
bumparker's Avatar
bumparker
Sorry I couldn't get that picture to post but it sounds like you got it figured out.
