Sponsored by: Real Truck
XL to XLT lights
Old Dec 3, 2009 | 09:42 PM
mczarski's Avatar
mczarski
XL to XLT lights
Hey all, new member here. I checked out the tech folder but did not see this question. What is needed to switch from the XL lights to the better XLT lights? Thanks.
Old Dec 4, 2009 | 02:08 AM
TexasRebel's Avatar
TexasRebel
conventional to aerodynamic?
just the new lights...
Old Dec 4, 2009 | 02:34 PM
mczarski's Avatar
mczarski
Yes, we have the old school rectangular sealed beam headlights which come on the XL models. I want to change to the XLT style lights with the replaceable bulbs that offer a better light pattern, and also a more refreshed look. Do I just need the housings and bulbs, or is there any wiring/fabricating needed. Thanks.
Old Dec 4, 2009 | 06:28 PM
Fordfanatic4life's Avatar
Fordfanatic4life
you'll need to change the pigtail aswell, as the plugin at the lamp itself is different from the basic XL sealed beam lamp to the aero-lamps of the higher trim line trucks...
Old Dec 4, 2009 | 06:59 PM
TexasRebel's Avatar
TexasRebel
in 2008 they shouldn't be...
the housings have the same connections from the wiring harness, but have different internal connections.
Old Dec 4, 2009 | 10:48 PM
LSchicago2's Avatar
LSchicago2
You didn't need to change the pigtail on the older trucks! Just unplug the headlight, go about 8-10 inches down from that plug to the next plug. Unplug there, and take the short harness off. The plug that's left works on the aero headlights.
Old Dec 5, 2009 | 12:46 AM
Fordfanatic4life
oh neat trick i didnt know they had both connectors from the factory...
Old Dec 5, 2009 | 02:02 AM
78bigbronco's Avatar
78bigbronco
Looks like he has an '02 FWIW.
And FWIW also (not much!) the aero-lamps are avail on the XL models now-a-days, I dont know about previous gens but now you dont have to get the xlt or higher to get em, its called the XL decor group.
Old Dec 5, 2009 | 04:48 AM
TexasRebel's Avatar
TexasRebel
I can't say I've ever seen a '99-'07 with sealed beams
Old Dec 5, 2009 | 03:42 PM
mczarski's Avatar
mczarski
Thanks guys, sounds like an easy swap.
Old Dec 5, 2009 | 11:08 PM
Franko72's Avatar
Franko72
Molon Labe
If your getting the flush lights off of a donor truck, make sure you get the up/down, left/right adjusters also.
I just did the opposite, I swapped out my flush lights for the XL style sealed beams.(my old ones were yellow/clouded, and full of moisture.)
I Ended up spending $40+ at the stealership buying the adjusters and the springs for the sealed beams.....If I didn't break my flush light adjusters, I would have sent them to you.
Old Dec 6, 2009 | 02:46 AM
78bigbronco
Crazy I seen plenty of them around. Back when they were new I actually liked the look of the sealed beams on the first gen... I thought if they would have just finished it off with one piece of curved glass in front it would be perfect. Until the 05-07 came out then I liked the aero ones a lot better. Even the 08-10 I like the sealed beam look on certain trucks, like all black ones. Only thing is though thier light output kinda sucks!
Old Dec 6, 2009 | 05:20 PM
mczarski's Avatar
mczarski
Ok, thanks, I heard you can wet sand the cloudiness and make them look almost new.
Old Dec 6, 2009 | 05:25 PM
TexasRebel's Avatar
TexasRebel
no kidding...
I love the look of the black on my grey truck, but really need more light. I just ordered fog lights...should be here next week. Will probably find some H/O sealed beams to replace the factory lights.
If I ever do go with the aeros, I've pretty much decided that I'll open them up and put a coat of black over the chrome
Old Dec 6, 2009 | 07:30 PM
78bigbronco
You and I think alike. Ever since I saw an all black harley edition 08 I have wanted the harley lights since they have black painted housing instead of chrome. I have heard some heat up their lights and take em apart but I havent heard anyone do that with the 08 & up yet so I didnt want to try... but that would be way cheaper than harley lights. I think I have seen knock off harley lights on ebay, not sure if I saw 08-10 ones yet though. But ever since everyone started accepting paypal only I stopped using ebay. I will not use or support paypal. So tell me more about DIY...
