i was wondering if i can fit the harley davidson headlights, or the 05 and up headlights on my 2000 F350. I really like the way they look, but want to make sure they'll fit before i invest in them.
2nd question. I currently i have a 3" lift, and have 305/70R16 tires. i was wondering what you guys thought about trying to fit 35s on it. 325/75R16
With a 3" lift you should be able to fit 315s on it, but you may rub the leaf spring at full lock up front.(Depends a little on the truck) If you have stock wheels though 215s are really pushing it because the stock wheels are only 7" wide. If you already have wider wheels with the proper offset you should be OK.
I think the 05'-07' grill and headlights fit on the 99'-04' models. Someone else will be along to confirm.
u have to trim the header panel to make 05+ HDlites work...
but it can be done...
i think u can buy "fake" Harley HDlites on Ebay that will fit ur truck with no mods... been awhile since i looked.. mind you they arent Ford parts so the fit and overal quality might not be there...
