Temp question
Old Dec 2, 2009 | 07:41 PM
jefxxo's Avatar
jefxxo
Temp question
I was hauling a trailer with a tractor (ford 9N) Not to heavy. My temp gauge gets close to the point of the dummy light coming on "engine temp". I wouldnt think this should be the case. The hill was pretty long and steep (about a mile long) Is there something I can do to keep my temp down? Anti freeze is good, radiator is clean. Would fans help? I dont know the exact temp I need to put a gauge on it yet. Could this be simply because the pump is turned up?
Old Dec 2, 2009 | 07:48 PM
starmilt's Avatar
starmilt
Did your fan come on.
Old Dec 2, 2009 | 07:49 PM
jefxxo's Avatar
jefxxo
It just has the fan blade on the engine. I was thinking about putting an electric fan on.
Old Dec 2, 2009 | 08:02 PM
IDIDieselJohn's Avatar
IDIDieselJohn
Maybe your fan clutch is bad.
Old Dec 2, 2009 | 08:06 PM
starmilt's Avatar
starmilt
When that fan on your engine comes own it sounds like a plane taking off if it is working properly you can't help but notice it.
Old Dec 2, 2009 | 08:14 PM
jefxxo's Avatar
jefxxo
I cant say i can hear it. At least not over the engine. It does spin when I start it and hit the pedal.
Old Dec 2, 2009 | 08:32 PM
starmilt's Avatar
starmilt
It will spin but when it locks up you will hear it and know it.
Can you turn it with your motor dead it should turn with some resistance.
Old Dec 2, 2009 | 08:39 PM
87crewdually's Avatar
87crewdually
Either hook up a mechanical gauge or temp probe to the upper rad hose and see what it's really running at. You may just have a faulty gauge which is common. If its confirmed getting hot then I'd start with fan clutch because like others had posted, it should lock up and roar.
Old Dec 2, 2009 | 10:27 PM
Dave Sponaugle's Avatar
Dave Sponaugle
If the light came on, you were getting hot.
Light and gauge are completely independant from each other.
I second the fan clutch is not locking up.
Old Dec 2, 2009 | 11:46 PM
starmilt's Avatar
starmilt
Exactly what is close to the light coming on.
Old Dec 3, 2009 | 10:09 PM
jefxxo's Avatar
jefxxo
I was running 80mph for a while and watched it go up. At a point my dummy light came on "engine Temp". So I slowed down and let it cool down. It was a very warm day, and this was before I had put on the new injector pump and lift pump. Is there a way to rebuild my clutch fan or just have to purchase a new one?
Old Dec 3, 2009 | 10:21 PM
87crewdually
Sealed unit. Buy New.
Old Dec 3, 2009 | 10:24 PM
Pkupman82's Avatar
Pkupman82
I have had my 6.9 working pretty hard on several occasions and never had any overheating issues. I have never seen it get over 210 degrees. I have my factory temp guage and an aftermarket mechanical hooked up and according to the mechanical guage the fan clutch locks up around 210 degrees. Does this sound right? IIRC the 6.2 and 6.5 GM diesels in the HMMWVs I used to drive would kick on the fan around 210. I also would say time for a new fan clutch, I think I paid between $70 and $80 for mine.
Old Dec 3, 2009 | 10:56 PM
Dave Sponaugle
That sounds about right for temp, but not for price.
The usual price is around 130.
Old Dec 4, 2009 | 04:30 PM
jefxxo's Avatar
jefxxo
Where did you pick one up for that price? I'm seeing them around $170.
