CPS Troubles?
Old Dec 2, 2009 | 10:08 AM
haulingboat's Avatar
haulingboat
CPS Troubles?
Hey guys,
Its been a long time since I have been on FTE. I see lots of familiar names still lurking around. I hope all is well.
My truck has been running well, until last night. Had a rainy wet drive home yesterday. Twice, while in heavy stop and go traffic, when pressing the go pedal I got nothing at all. No response what so ever. Each time the problem only lasted one or two pumps of the pedal then everything went back to normal. The second time it happened the SES light flickered on very breifly.
This morning she fired right up and drove beautifully all the way to the office (no rain).
I have read about CPS/rain issues and think that is what I experienced. I have not had the recall done as of yet (despite the repeated letters from Ford) because everything has been fine up til now.
Questions- Am I barking up the right tree (CPS)? Do I take it to Ford for the recall or install the grey one that has been riding around in my glove box for the last three years? Am I better off buying a black IH CPS?
Thanks in advance.
Old Dec 2, 2009 | 10:25 AM
Ponyboychris's Avatar
Ponyboychris
Usually, CPS issues in a stall problem and not a dead pedal. You might be experiencing a bad throttle pedal assembly. They are a known issue. I had one replaced under warranty by the PO - according to my OASIS report.
Old Dec 2, 2009 | 10:44 AM
haulingboat
Thanks for the reply. I'll do a search on the pedal assembly.
Old Dec 2, 2009 | 10:50 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Can you get the codes read? If the SES light came on, there should be codes.
I agree with what Chris said.
Old Dec 2, 2009 | 11:45 AM
haulingboat
Going to swing by DI today after lunch and see if David will read the codes.
After reading about the TPS it sounds like that is my problem. Is the Dorman sensor a suitable replacement? There appears to be some debate.
Thanks again,
Old Dec 2, 2009 | 11:48 AM
onelionhunter's Avatar
onelionhunter
Partsguy ED
When mine failed a few months ago, I ordered an entire new pedal assembly from Ed, 5 minute swap and extremely reasonably on cost.
Tom
Old Dec 2, 2009 | 11:51 AM
riverrat41's Avatar
riverrat41
Thanks again,
I have a spare if you are in a bind.It is not new but it was working when I changed it out,just thought it was time for a new one at 200k
Old Dec 2, 2009 | 01:30 PM
haulingboat
Thanks for the offer. I am not in a bind at this point.
I am always amazed at the good people on this site.
Thanks again,
Old Dec 2, 2009 | 01:37 PM
Parts Guy Wyatt's Avatar
Parts Guy Wyatt
Former Vendor
Tom
Old Dec 2, 2009 | 01:41 PM
haulingboat
Originally Posted by y2kfordparts
Ed,
Do I need the entire assembly or just the 699-203 sensor?
Old Dec 2, 2009 | 01:57 PM
Parts Guy Wyatt
Former Vendor
Ed,
we taking about the CPS or the TPS?
not sure what a 699-203 is
the TPS sensor is part of the pedal assy and can only be purchased as a assy
there are two different ones depending on production date so it best to send be the vin to be sure.
the CPS(black) is no longer avail and has been replaced by the grey one F7TZ12K073B there is a recall out on this also.
Ed
Old Dec 2, 2009 | 02:14 PM
haulingboat
Ed
Sorry for not clarifying.
I was refering to the TPS. I read thru a few TPS threads that recommended a Dorman sensor rather than the entire assembly. I thought they linked to your site, but apparently not. Dorman 699-203 is the part # for the 2002 model according to the link posted.
What does an entire assembly sell for? I have a 2002.
Old Dec 2, 2009 | 02:22 PM
Parts Guy Wyatt
Former Vendor
fixed or adjustable pedal?
1C3Z9F836C fixed
2C3Z9F836DE adjustable
can't post prices on open forum(too low)
so please check my site, pray you dont have adjustable. big bucks.
ed
Old Dec 2, 2009 | 03:03 PM
haulingboat
1C3Z9F836C fixed
ed
I'll check it out. Thanks again.
Old Dec 2, 2009 | 03:08 PM
Parts Guy Wyatt
Former Vendor
YOU ARE WELCOME!
