While I am here
Old Dec 2, 2009 | 09:54 AM
OleGrouch's Avatar
OleGrouch
While I am here
the 89 F-250 w/351 and whatever trans they put in it, did know but forgot, anyway its having a problem, it shifts down out of overdrive and back at full speed a lot here lately, whats happening ? Can it be repaired on the truck or does it have to come out or be replaced, anyone ? Bobby
Old Dec 2, 2009 | 09:58 AM
alxsnmr's Avatar
alxsnmr
It is most likely to be an E4OD if it is a 351 in a 3/4 ton. If it starts searching for gears like you discribed, first check the fluid level and condition of the fluid which it can tell you alot quickly. Though the 89 E4OD was one of the first versions and most problematic generation. You may need a complete rebuild which will require removal from the truck.
Old Dec 2, 2009 | 10:05 AM
Redneck1465's Avatar
Redneck1465
If the trans is bad you will need to pull it.
