I have a 64 f100 custom cad and I want to put a new engine in it. What engines would be a direct bolt on without any mods. 300??? I think I have a 240 or a 223
NONE, NOTTA, sorry. There are mount kits available for side mount upgrade, though.
I think the taller valve cover on the 262 is one way to tell.
edit: wrong... they look the same (i did a google search) the blocks look a little different
if you have a way to chech the stroke it should be 4.03 for the 262.
I thought all 262s came with a factory twin turbo, fuel injection, and burned unicorn farts.
Are you looking to rebuild this engine or git rid of it gvilleharley? The 223 is a good reliable engine for the most part and major parts are still avialable. The 262 is good, but harder to find parts for.
precision sells a reman 223 for about $1900 not counting the $750 core.
Finding a 223 in good shape to use will be kinda hard. If the one you have runs I would sugest looking for a good core and having that rebuilt then doing the swap.
Should cost about $1200-1400 with a carb kit and new clutch in it too.
Rebuild kits are about $750 and machine work should cost about $300-400 if you do the assembly yourself.
