Just checking,,
Old Dec 1, 2009 | 04:18 PM
Ford400Man's Avatar
Ford400Man
Just checking,,
a 1995 5.8 is interchangeable with a 1991 5.8, Right? I was thinking it was up to 96 that works and 1997 and up will not,,,,
Old Dec 1, 2009 | 05:23 PM
Linemo's Avatar
Linemo
yes but there are some differences first and this one is a plus the 95 engine is factory roller camshaft the other thing is look at your AIR tubes your 91 should have it runnning between the heads in back the 95 could be this way or it could come from the back of the head to the manifold on the drivers side those are the obvious things that stick in my mind!
Old Dec 1, 2009 | 05:52 PM
Ford400Man's Avatar
Ford400Man
Thanks. I don't know if it came from a car or truck, I may have to swap out the pan and top side. So if anything, I will put the original tubes from mine on the motor. I have parts from the motor that was in my Bronco,, but the heads are bad.
