Mirror Skull Cap
Old Dec 1, 2009 | 02:32 PM
DocZ's Avatar
DocZ
Mirror Skull Cap
Have a 2010 F-150. Wanting to find either chrome or painted skull caps for the mirrors. Anyone know who sells them?
thanks.
Old Dec 1, 2009 | 02:58 PM
Going_Going_Gone's Avatar
Going_Going_Gone
Ford sells smooth primed paint-to-match caps and chrome ones too. I just ordered a pair of paint to match for my 2010 XLT from Tasca Ford in Rhode Island. Part numbers are:
9L3Z-17D742-BAPTM (Right cap)
9L3Z-17D743-BAPTM (Left cap)
...around $27 each plus shipping plus the cost of having them painted by a body shop
not sure of the numbers (or the cost) for the chrome ones.
Old Dec 27, 2009 | 05:33 PM
DocZ's Avatar
DocZ
Got another question
Do I need to use special primer and paint on these plastic skull caps? Planned on using Duplicolor primer and paint. Been told I should use primer and paint made for plastics like they use on bumpers, etc.
Old Dec 27, 2009 | 08:45 PM
LMS Residential's Avatar
LMS Residential
If you're going to spray them yourself, make sure you use an adhesion promoter first. Follow the directions to the letter and the finish will grip much better and last a lot longer.
Old Dec 31, 2009 | 09:25 AM
DocZ's Avatar
DocZ
Anything I need to know about removing the mirror glass to install the new caps?
Old Feb 1, 2010 | 12:18 PM
Going_Going_Gone
Here is a good source for information on how to remove the glass. You will need a long, very thin-bladed flat screwdriver and about the only way to loosen the glass is working from the outside bottom of the mirror and, once you get the mirror glass to separate, keep the mirror tilted the same way and start working the screwdriver alternately in both directions around the attaching plate. You will hear creaking as the clips release and all of a suden it will pop off.
http://www.kwmuth.com/techsupport/pdfs/21000960.pdf
Last edited by Going_Going_Gone; Feb 1, 2010 at 12:21 PM. Reason: add more information
Sparks123
Ford Truck Parts for Sale
Aug 27, 2017 05:47 PM
6thf150
New Member Introductions
Mar 29, 2017 09:46 PM
REPO.
Feb 8, 2017 12:35 PM
Firefighter 1406
WTB - Parts & other
Dec 21, 2016 08:44 PM
Tawn
Oct 17, 2016 04:07 PM
