Does anybody know what thread size the transfer case fill plug is or a part number? I called the local dealer and they said they weren't for sure???? '99 F-250 7.3 electric shift
I haven't ever removed mine yet. But I'm pretty sure it's the same as the plugs on the diffs. 1/2"bsp, common pipe taper thread (which appears to be about 3/4" in diameter.)
OK, I tried the local hardware but couldn't get it to thread into anything so I thought it was metric maybe? I went to the dealership and he guessed at a number on the exploded view he thought it would be and it was correct(lucky). I will call back tomorrow and get the info in case someone else needs to know.
