Stupid question
Old Nov 30, 2009 | 12:37 PM
PhotoJoe's Avatar
PhotoJoe
Stupid question
Ok, I'm embarrassed to even ask this, but I've been a Chevy guy all my life and this is my first Ford (and most certainly NOT my last!). I need to pull my front wheels to check brakes, but I'm not sure how to jack this twin I-beam suspension. Any tricks? Anything to avoid. I guess I could jack it by the frame in the middle and lift one entire side of the truck. Everything up front seems to have a thin flange as the lowest point and I don't want to damage anything. Thanks for helping the noob, even though I've had the truck for 2 years!
Old Nov 30, 2009 | 01:17 PM
Monsta's Avatar
Monsta
Sit. Stay.
Depends on the jack you're using. If you're using the stock jack, lift it right under the ball joint. If you use a big floor jack, lift it via the frame.
Old Nov 30, 2009 | 01:18 PM
PhotoJoe's Avatar
PhotoJoe
Floor jack and jack stands. Frame it is.
Thanks.
Old Nov 30, 2009 | 03:42 PM
VaSheriff's Avatar
VaSheriff
Chuck Norris can lift it with one hand, and hold it up for you!
Old Nov 30, 2009 | 05:21 PM
CanadianSmokie's Avatar
CanadianSmokie
Chuck Norris doesn't have to lift it... he just stares at the truck and it lifts itself.
