Sponsored by: Real Truck
cruise control wiring
Old Nov 30, 2009 | 11:41 AM
Jerrywgroah's Avatar
Jerrywgroah
I have what is called a '97 F250 super cab truck. The build date is 02/'97. Apparently a lot of the wiring and componenets are from '96 or earlier.
I am having problems with the cruise control wiring. my cruise control switch is on a stalk on the column, not on the steering wheel. In touble shooting I found that someone had cut the wires in the harness coming from the control module under the hood.
There are 4 pins in the module connector, but only three wires used (2 pins with yellow/black). One of yellow/black appears to be stowed.The other wires in the harness are white/red, yellow/black and brown/white.
Lookig at the connector from the latch side, one yellow/black wire is on the RH side of the connector, the other is between the brown and white wires.
Does anyone have a diagram that would show me where to find where the above wires connect?
Thanks in advance, Jerry
