ok. so first off.. great forum and most people on here here seem very knowledgeable. now, i've just purchased a 95 f150 L6 and i've been searching and searching for the last week almost trying to find what the best cam is for the 300. i realize that the comp can only handle so much.. so without efi modification what cam could i use? also, with efi modification (troyer performance or diablo chip) could i use a less mild more wild cam? i'm really hoping to get somewhere around 200-250 hp as this will be a daily driver. and please.. i'm going to keep it efi.. i dont want a caburator.. so please nobody tell me how much better a carb is.. i get it.. i just want the drrivability that have.. with more power.. thanks in advance -J
1. Check with cam manufactures like Isky and Comp, etc., for computer compatible cams.
2. Forget the "chip" deal...they are generally considered unproductive of good results. ROI is virtually nothing.
3. Any significant performance gains in these vehicles usually come through a MegaSquirt controller system coupled with a turbo.
4. Keep on searching and reading...this subject is quite common on this Forum and others too. Try these:
