Performance questions????
Old Nov 29, 2009 | 12:42 PM
7.3 junkie's Avatar
7.3 junkie
Ok well it seems my other ford techs are clueless when it comes to the performance. Currently I have an Afe stage 2 intake, 3in downpipe and 4in exhaust, and a superchip. Honestly i hate the superchip worst mileage ever however decent power. So id like to go with maybe a ts performance chip..... Soon will be coming my guages and and banks intercooler. So i want to eventually run a bigger turbo, 50 to 100hp injectors, and a bigger lift pump for the injectors fyi mines leaking and needs replacement. So does any one have ideas on a chip, turbo, injectors, and fuel pump????? i would like the best bang for my buck. I found many of parts on the internet but not alot of info about the products. Thanks
Old Nov 29, 2009 | 12:56 PM
7.3 junkie's Avatar
7.3 junkie
Oh and i dont know why but in town 100 miles to a full 15 gallon tank I hate it and the lift pump is not leaking that bad either however I want more power and better fuel economy!!!!!!!!!!!!!!!!!!!!!!
Old Nov 29, 2009 | 01:17 PM
KonaGrown's Avatar
KonaGrown
For Chips, there are the TW Chip, PHP Chip, or DP tuner.
Old Nov 29, 2009 | 02:03 PM
Brown Falcon's Avatar
Brown Falcon
THese trucks don't really have a "lift-pump". It's a High Pressure Oil Pump that runs the injectors.
I love my PHP chip. Good power, same or better MPG... Injectors I'd look into Rosewood Diesel at DIY-Injectors.com
For turbo it depends on what you want to do with it and how much power. A cheaper upgrade would be a D66 from Bean's. But if you really want power a H2E setup would be best.
A good aftermarket electric fuel system to replace the mechanical one is a good upgrade.
And for your HPOP (high pressure oil pump) either a Adrenaline pump or a Terminator Engineering pump.
Old Nov 29, 2009 | 04:05 PM
rideracelivemx7's Avatar
rideracelivemx7
holy snot dude, you get 100 miles out of 15 gallons?? i get 300 miles out of 18 gallons driving halfass and econo mode, ditch that chip and get a dp or wildman or php, do you drive like a jerk or what?? dang lol
Old Nov 29, 2009 | 08:04 PM
952X4's Avatar
952X4
I can get 300-330 miles out of a tank on 15 gallons, that's with a Dp-tuner chip running the 80 HP Econo tune.. My mileage went up a good 1.5 - 2 mpg since I put it in, great chip.. Must be something really wrong if you can only get 100 miles a tank
Old Nov 30, 2009 | 03:36 PM
bleeds blue's Avatar
bleeds blue
I have the old gold superchips in mine. I'm on 35's and usually cant keep my foot out of her. I still get around 13mpg on average
Old Nov 30, 2009 | 03:52 PM
Cuda_jim's Avatar
Cuda_jim
The fuel pump must be leaking more than you think. I'll bet the fuel odor is pretty bad.
Diesel will evaporate when it's gets hot, and there's lots of hot places in the engine valley......if it runs down the back of the block....at least the bottom of your truck won' rust
Old Nov 30, 2009 | 04:02 PM
strokin'_tatsch's Avatar
strokin'_tatsch
I get around 300 miles to 15 gallons in mine as well and i use Tony's tunes and it hardly ever comes out of extreme tune. ditch the super**** and get ya a good chip for that thing. i would talk to Tony Wildman @ Total Diesel Performance, Jody @ DP-Tuner, Bill @ Power Hungry Performance, Matt @ Gearhead Auto, Swamps, and Beans. Once you talk to them then you can decide which one your more comfortable with tuning your truck.
injectors aren't based off of power levels for our trucks like dodges. ours go by CC's. your stock injectors are 90cc. stage 1's are 160cc w/ stock nozzles, 2's are 160cc w/ 80% larger than stock nozzles, 3's are 238cc hybrids w/ 100% larger than stock nozzles, etc.... each injector step requires more and more to make it reliable. stage 2's will eventually eat your stock turbo and you will then want to step up to an H2E or something like it. stage 1's work well with the stock turbo or a D66 turbo from Beans. the D66 will get eaten up by stage 2's IMO. so if you run stage 2's with an H2E then its a good idea to throw in some head studs to keep from blowing the head gaskets. H11's are my recommendation, but you can go with ARP's if you like... to run bigger injectors you need the fuel system. electronic regulated return is the way to go. i use the dieselsite CPR fuel system and i love it.
Also, you can plumb up a stock super duty IC to work in your truck or a stock 6.0 IC to work instead of spending the money on the Banks IC. hope this helps. haha
Old Nov 30, 2009 | 05:36 PM
MADVAN's Avatar
MADVAN
Jim
Him and his budd's are ford diesel tech's.
He needs all the help he can get.
My thoughts are is it should run right before
even thinking about performance mods.
Bill
Old Nov 30, 2009 | 05:41 PM
Cuda_jim's Avatar
Cuda_jim
That explains it ...........haha!
Old Nov 30, 2009 | 06:42 PM
WALJON's Avatar
WALJON
LOL
Old Nov 30, 2009 | 08:54 PM
strokin'_tatsch
Originally Posted by MADVAN
Jim
Bill
OUCH!!! glad you don't speak your mind or anything there Bill. haha
Old Dec 1, 2009 | 04:27 PM
stokedguy's Avatar
stokedguy
wat would be the main cuz of bad mpgs i'm only getting 150 miles off one tank. i have a ts chip 6637 and the bb mod also there is a ohm resistor in the air box sensor need some help here dont know where to start
Old Dec 1, 2009 | 04:38 PM
MADVAN's Avatar
MADVAN
According to the post its at 6.66 MPG!!!
That shure is a Devil of a problem.
Bill
