will not start
Old Nov 29, 2009 | 12:35 PM
KCMAGERS's Avatar
KCMAGERS
Angry will not start
I know there are threads for this but I cant find any that show my problem. it turns over just fine, WTS light will not come on at all, it is a nice 44 F, I plugged in my reader and it shows NO errers. So how ****ed am I?
Old Nov 29, 2009 | 12:47 PM
Copedawg's Avatar
Copedawg
I don't think you are ****ed at all. Do you have white smoke when you are cranking? When you turn the ignition "ON" do you have a good drop in your battery meter? Is your tach bouncing when you crank?
Old Nov 29, 2009 | 12:59 PM
KCMAGERS's Avatar
KCMAGERS
Good Volt drop no tach movement cant see white smoke
Old Nov 29, 2009 | 01:08 PM
Copedawg's Avatar
Copedawg
You think your CPS may have went? If you batteries are good-n-charged you should get tach bounce. Try to jump it with another vehicle and see if the tach bounces. No smoke means no fuel (I believe). Does/did it ever cut off and start back up recently?
Old Nov 29, 2009 | 01:11 PM
Action4478's Avatar
Action4478
Check fuse 22 under the hood , if blown , unplug the fuel heater ...
Old Nov 29, 2009 | 01:18 PM
KCMAGERS's Avatar
KCMAGERS
all fuses are good
Old Nov 29, 2009 | 01:23 PM
KCMAGERS's Avatar
KCMAGERS
I am going to go get a CPS and try it
Old Nov 29, 2009 | 01:34 PM
Action4478's Avatar
Action4478
it turns over just fine, WTS light will not come on at all:
You may want to look closer at the fuses 9& 22 Or a Relay in the under hood fuse box
Look here ....
CPS won't cause a no WTS light...
Old Nov 29, 2009 | 02:09 PM
MADVAN's Avatar
MADVAN
What he said
B
Old Nov 29, 2009 | 02:23 PM
KCMAGERS's Avatar
KCMAGERS
all fuses are fine new CPS still same thing
Old Nov 29, 2009 | 02:31 PM
KCMAGERS's Avatar
KCMAGERS
what will make the WTS light not to light?
Old Nov 29, 2009 | 03:14 PM
Hussler's Avatar
Hussler
Fuse #22. It powers the PCM. Did you pull it out and check with an ohm meter? These are under hood fuses and not the ones in drivers compartment, just in case you did not know.
Old Nov 29, 2009 | 03:34 PM
KCMAGERS's Avatar
KCMAGERS
I replaced CPS and then replaced #22 the cps was leaking now she starts
Old Nov 29, 2009 | 03:40 PM
Hussler's Avatar
Hussler
Old Nov 29, 2009 | 03:48 PM
KCMAGERS's Avatar
KCMAGERS
Thank you all for help !!!!!!!
