Keyless entry code for 2001 Expedition
Old Sep 1, 2002 | 01:38 PM
mbunney's Avatar
mbunney
I recently purchased a used 2001 Expedition. In order to operate the keypad on the door you need the factory default number. The manual says that the number can be found on the computer. Can someone tell me where to find the computer?
Thanks
mbunney
Old Sep 1, 2002 | 08:47 PM
TLindquist's Avatar
TLindquist
I just bought a 2000 EB 4x4. I read the same thing, don't bother, take the EX to the dealer and they will use the VIN to get the default code or they will "hook up" a computer scanner and scan for the code. Once you have the default code WRITE IT DOWN ON THE SAME PAGE FOR THE INSTRUCTIONS ON HOW TO CREATE A CUSTOM CODE. This way you'll always know where to look.
Old Sep 2, 2002 | 08:48 AM
Acamar's Avatar
Acamar
[updated:LAST EDITED ON 02-Sep-02 AT 09:49 AM (EST)]They will also charge you an arm and a leg, too!
I have a '99, so the instructions might be different. Crawl into the wheel well of the driver's side, and look up into the dash, toward the outside of the truck. You will see a black box, with a white label, with a bunch of numbers and sometimes "bar codes" on it. The big five digit number is your master number.
Old Sep 2, 2002 | 01:01 PM
mbunney's Avatar
mbunney
Acamar,
Thanks, I found the code over the brake pedal on a black box. I really appreciate your help.
Thnaks again.
Old Sep 4, 2002 | 06:53 AM
Acamar's Avatar
Acamar
No problem! This board saved me hundreds of dollars with their tips, so I'm returning the favor!
Old Sep 4, 2002 | 05:03 PM
98BIGBODY's Avatar
98BIGBODY
Old Feb 18, 2007 | 09:15 PM
quint32's Avatar
quint32
Thanks for the help!!
I just got a 2001 Expedition EB and it was right where you said it was. It was on a white box right above the steering stem. This might help with some confusion because in mine there was a black box a little lower with a 5-digit code and a white box deeper also with a 5-digit code. A little trial and error and it worked.
Old Dec 30, 2017 | 06:47 PM
Jesse Reagin's Avatar
Jesse Reagin
This is exactly right. Worked for my 01 eddie bauer
Xavier Cadillac
Nov 20, 2017 09:00 AM
Xavier Cadillac
Nov 19, 2017 10:48 PM
windgust
Oct 20, 2016 12:52 PM
Silentfisch
Electrical Systems/Wiring
Mar 26, 2016 01:17 PM
jakvisualdesign
Feb 28, 2016 08:28 PM
