Sponsored by: Real Truck
Headlight troubles
Old Nov 29, 2009 | 10:02 AM
timboleather's Avatar
timboleather
Headlight troubles
I'm new to this so don't chastise me.
I recently had a hiniker plow put on my 2000 F250.
Somehow when hooking the wiring up they screwed up.
At first just my low beams did NOT work but high beams did.
Yesterday driving home from work at dusk i noticed that neither the high or low beams worked.
Yes the headlight switch is on dash lights work and the running and signal lights all work just not the headlamps.
How do I(not them) fix this.
Old Nov 29, 2009 | 10:46 AM
bpounds's Avatar
bpounds
Since the highs worked for a while, and then they went out too, I suspect they pinched some wires up front while working on mounting the plows. If so, it has blown one or more fuses. First thing to do is to find the blown fuse(s) and replace them. But don't be suprised if they immediatly blow again, at which point you have to find the shorted wires.
If there are no blown fuses, then it gets more complicated, and I would start by finding all the wiring they added on and temporarily disconnecting it in an effort to get back to a stock truck with good electrical.
Old Nov 29, 2009 | 01:08 PM
Rongold's Avatar
Rongold
Talking NO HEADLAMPS
Check to see if your headlamps burned out--anything is possible. There is also a website (forum) devoted to plowing. It is
http://www.plowsite.com/
The people there are a storehouse of knowledge on plows, just like here with Ford Trucks. There is a Hiniker section of the forum where you can ask your question.
GOOD LUCK,
RON
Old Nov 29, 2009 | 01:26 PM
timboleather
thanks guys
I actually just finished fixing it.
I think this is what happened:
When they went to hook the plow light wires into headlamps and stock truck wiring, it looks like they bent the headlamp plug wires too much and one broke.
Probably also due to age of the wire as well. Can't blame the installer for everything.
I cut the wires bought a new plug respliced them.
Works like new again!
Hell ya!
Nothing like finding the problem and fixing it for under twenty bucks by yourself. Makes the chest stick out a little farther and the chin up a little higher.
Walked in the wife said "whats wrong with it."
In a deep manly voice I said "Nothing, I fixed it!"
