whats a glow plug delete mod?
Old Nov 28, 2009 | 08:48 PM
branden.w's Avatar
branden.w
having huge problems with my electrical. less electrical the better anyway.
Old Nov 29, 2009 | 10:21 AM
Dave Sponaugle's Avatar
Dave Sponaugle
Not something you would want to do.
The thought was lowering the compression ratio, which is not important unless you have a turbo and are running high boost.
The proper way to lower compression is mill the pistons, not pull and delete the glow plugs.
A reliable starting engine is more important.
Old Nov 29, 2009 | 03:26 PM
branden.w's Avatar
branden.w
oh ok, i saw someone had that done. yea ill keep the glow plugs in, mad snow where i live anyway. i thought maybe he got rid of the controller and relay and put a push button or switch in place. thanks again dave
Old Nov 29, 2009 | 04:38 PM
starmilt's Avatar
starmilt
Personally I like the manual GP's and there are several very detailed threads on the subject in here.
I can't imagine cutting the gp's off to lower the compression it can't gain much.
Old Nov 29, 2009 | 04:58 PM
dyoung14's Avatar
dyoung14
im going to switch to an intake heater, im tired of glowplugs swelling and breaking in the head, plus it lowers compression so its a win win i think
Old Nov 29, 2009 | 11:16 PM
Dave Sponaugle
When you look at what the volume of the tip you cut off is, the compression ratio can't change that much.
Branden is you want to go manual with the glow plugs that is an easy thing to do.
Remove the white wire from the relay.
Attach a wire to that terminal and run it i the cab.
Attach it to a momentary switch on one terminal.
Attach a wire to the othe rterminal and run it to a good electrical ground under the dash.
Done wiring.
Operation, turn key to on
Depress momentary switch for 10 seconds or less
Start the engine
Old Nov 30, 2009 | 06:02 PM
branden.w's Avatar
branden.w
your the man dave, thanks again
command37
Jun 2, 2017 02:21 PM
slownsy
Ford Truck Parts for Sale
Jul 29, 2016 06:02 PM
Nathan Cox
Apr 30, 2016 08:32 AM
Merlin68F-100
Feb 25, 2005 07:49 PM
The Phenom
1997 - 2003 F150
Nov 30, 2003 07:59 PM
