Sponsored by: Real Truck
Dome light wiring missing
Old Nov 28, 2009 | 05:35 PM
idgara73612's Avatar
idgara73612
So I just bought a used 2006 F-250 King Ranch about a month ago, and since I've had it, the rear dome light (and map lights) have not worked. I finally got around to taking off the light enclosure today and discovered that the problem is that there are no wires connected to the light. I looked around inside the frame as much as I could, but couldn't even find the loose wires that have been disconnected.
Has anyone else come across this? I'm trying to figure out the best plan of attack here. Is there a wiring harness i can buy to plug-in, or is it something I'm going to have to have the dealership wire for me? Also, any ideas on cost?
Thanks!
Old Nov 28, 2009 | 06:55 PM
Rongold's Avatar
Rongold
WIRING
The wiring has to be there--Every truck regardless if it's a base XL to a King Ranch had a dome light. It probably pulled forward above the headliner. I don't know if your headliner is similar to mine, but just remove the 2 coat hooks, and the dome lamp, and you should be able to pull the headliner down enough to see in there and look for the harness. Did you buy the truck from a Ford dealer ??? If so, tell them that you pulled the dome lamp to see why it doesn't work and you found that the harness is not there--That's their problem.
RON
Old Nov 28, 2009 | 08:31 PM
idgara73612
That was it! I took off the light and the two plastic anchors on either side and was able to pull the headliner down enough to see them pulled back only about 2 inches. The previous owner had spliced into the harness for some extra lights (and left the splices there), and when they took out the lights they just didn't bother to plug it back in. Thanks a lot Ron! That's been bugging me for about a month.
Old Nov 28, 2009 | 08:35 PM
joe chevy's Avatar
joe chevy
now you need to send some reps to ron
Old Nov 29, 2009 | 06:13 AM
redford's Avatar
redford
FTE Leadership Emeritus
The missing wire was found after an intense search. Foul play is not suspected.
