How to remove Rear Differential.
Old Nov 28, 2009 | 04:52 PM
cheetah85's Avatar
cheetah85
I have a 1992 f150. I am replacing the rear differential bearings. I have removed the cover, drained the fluid, pulled the pin, removed the c-clips, pulled the axles and now am confused on what to do next.
Do I remove the 4 bolts that holds the collar on over top of the bearings? After the 4 bolts are removed, does the differential slide out.
I am no mechanic but I think I can complete this job. I just ordered a differential repair kit, National Brand, part# RA-311. The parts store said it had everything in it to complete the job.
The reason I am replacing the bearings in the differential is because I was getting a vibration and upon inspection of the rear end, I put the truck on jackstands and with my hand spun the axles and a thumping sound is coming from the differential area that speeds up the faster I turn the axle by hand. You can also feel the thump on your hand. My neighbor said it is probably coming from the differential and to replace the bearings.
Old Nov 28, 2009 | 05:05 PM
Volvo92906's Avatar
Volvo92906
Did you take off the pinion to drive shaft flange? After that, yes remove those 4 bolts and the internal gears should all just come out of the housing. But, if you will reuse the old stuff it has to go back in the same positions, just like crankshaft bearings do.
Old Nov 28, 2009 | 05:08 PM
Diesel_Brad's Avatar
Diesel_Brad
Yes the carrier will now come out. You may need to pry it out and have to beat it back in w a dead blow hammer
Old Nov 28, 2009 | 05:20 PM
wyazel1's Avatar
wyazel1
Put a rag in between the ring and pinion and spin the pinion it should force itself out just be careful you dont want to let it drop to the ground.
Old Nov 28, 2009 | 06:48 PM
Ford6.02005's Avatar
Ford6.02005
FYI-when you spin the axle shaft by hand the only things you are turning are the axle shaft,side gears,and pinion gears.The differential side bearings only turn when the ring gear and case turn!They always feel kind of "rough" when you spin internal gears by hand.From personal experience rearends typically do not cause vibrations...It's usually caused by tires,u-joints,out of balance driveshafts,etc.You are 4 bolts away from inspecting your bearings-just remember to mark your bearing caps so they can be reinstalled the same way they were!Case should be a tight fit into housing-2 pry bars work well to remove. Just be ready and do not let it fall. Keep shims side for side also.
Old Nov 28, 2009 | 06:57 PM
Conanski's Avatar
Conanski
In general the main differential bearing never fail.. I have never seen or heard of one failing as long as the diff has oil in it anyway. It is more common for the outer bearing to wear and with high milage trucks the bearing surface on the drive axles also wears down. You're seconds away from inspecting these now so go ahead but also get a bearing puller and change the outside bearings and seals even if you don't end up replacing the diff bearings. That have to be pressed off and on by the way.
Old Nov 28, 2009 | 08:43 PM
MisterCMK's Avatar
MisterCMK
I've seen and heard of carrier bearings failing. Our Rams chew up the carrier and pinion bearings after 100k or so. The Expedition had a carrier bearing that was pitted and looked really bad when we rebuilt the Trac-Lok in it. Granted these are not 8.8s but it does happen.
88_F0RD
Aug 27, 2016 02:22 PM
Stlrrig
Escape & Escape Hybrid
24
Aug 8, 2016 12:49 PM
F250F250F250
Nov 17, 2012 07:40 AM
cheetah85
Nov 29, 2009 07:50 AM
ratwell
Oct 23, 2003 09:52 AM
