Sponsored by: Real Truck
4x4 light out
Old Nov 28, 2009 | 04:26 PM
Northbound2011's Avatar
Northbound2011
4x4 light out
I have a 02 F350 and the 4x4 light on the switch doesn't come in High or Low and the transfer case doesn't engage.
The 4x4 light on the dash flash for a second at start up.
Any clues for what I should look for?
Old Nov 30, 2009 | 03:40 PM
Downriver Thunder's Avatar
Downriver Thunder
Your xfer shift motor is probably dead. It needs to shift to 4wd to apply power to the light.
Old Nov 30, 2009 | 05:05 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Disconnect the two-wire connector at the servo motor on the transfer case, and hookup a test light to the two wires.
With the engine running, turn the 4x4 switch from 4x2 to 4x4, wait a few seconds, and switch back, and watch the light. If the light comes on, the servo motor is bad.
If the light does NOT come on, you have a bad fuse or shift relays, or something else is going on.
After doing the test light thing, report back and let us know what's going on.
