1978 - 1996 Big Bronco
Adjusting Front Fender Forward
Old Nov 28, 2009 | 12:29 PM
mprice's Avatar
mprice
When I bought my '96 Bronco the passenger's side door didn't seal at the top. I figured it was bent but when I started looking at it I found that the PO (I hope there's a special place in hell for POs) had adjusted the hinges so it would clear the front fender when it opened. It doesn't clear because the front fender on the passenger side is about 1/2 inch too far back. Looking at the driver's side the windshield frame is even with the top rear corner of the fender but on the other side the top rear corner actually is rubbing the paint off of the A pillar.
I looked in both the Chiltons and Ford manuals but neither one has very good info unless I'm trying to do a complete frame-off restoration. Can someone tell me what bolts I need to loosen so I can just slide that panel forward?
Old Nov 28, 2009 | 04:40 PM
rbloodhound's Avatar
rbloodhound
Sound like it has been crashed in it's past.
you should be able to loosen all of the fender bolts and adjust it that way.
Old Nov 30, 2009 | 12:45 PM
mprice's Avatar
mprice
Yup, I'm just not sure exactly which ones. I've removed the two up close to the windshield, loosened the four at the front corner and the one down at the bottom rearward from the tire. I think I also need to take out the battery tray and remove the one that is the lower hood pivot. I'm tempted to just take it to a body shop for an estimate.
Old Dec 3, 2009 | 04:57 PM
04redstroker's Avatar
04redstroker
cant remember where all the bolts are at, but it is very easy. And BTW a paint mixing stick seems to be the perfect thickness for setting the gap.
Old Dec 4, 2009 | 08:54 AM
mprice's Avatar
mprice
Great idea, I'll try that. I think what I was missing was taking out the battery tray. I haven't had time to get back to that part of the project but I was able to make more sense out of the factory manuals in the mean time. This weekend I should be able to get it sorted out.
Old Dec 6, 2009 | 08:52 AM
MustangEd's Avatar
MustangEd
I believe there is also a fender bolt that is accessed thru the
gap in front of the door when the door is open. I know there
is a bolt there on the older models of the same body style.
Old Dec 7, 2009 | 10:09 AM
mprice's Avatar
mprice
I fussed with it some Saturday but still couldn't figure out what I was missing on the front end. It was free except for up by the lights. Anyway, I put a bottle jack on the inside to use as a ram and pushed the whole thing forward about .5" and bolted it back down. Now it's got a little preload but who cares. Thanks all for your help.
AXracer
26
Jul 29, 2023 10:54 PM
hardknox00001
Paint & Bodywork
Mar 30, 2014 07:32 AM
Fishin76
Oct 18, 2010 06:42 AM
xfordman
35
Mar 18, 2005 05:25 PM
