First of all, i want to say what a great help this sight is. Alot of my questions have been answered just by reading through other post. anyway my 97 250 has a neck breaking 2-3 shift. I saw where people drilled out the valve body to make this happen, how can i tell if this was done to my truck,if so, is it reversable? also sometimes it seems to up shift instead of downshifting when iam trying to accelerate. help.
You have to drop the pan, pull the filter out and then take off the Acc. Body. It's the front-most piece in there.
If it is drilled out you can have the holes welded shut (not easy to do) or what I was told by a local tranny builder was to stick a small piece of wire through the hole and bend it on both sides so it blocks the hole.
Hope this helps! Good luck!
Oh yeah, is it harsh all the time? Or is it only harsh under hard throttle? Does it shift easier if you aren't giving it much gas?
its only like that under hard throttle. yes, its been like that since i got the truck. i dont know if it been drilled or not. i know the guy i got it from didnt do it.
Sounds like a Accumulator Body or Valve body issue.
Originally Posted by chicagodragon
do you also know anything about it seeming to up shift to quickley? i read a few post about this, but nothing really helped. thanks
Maybe a faulty Speed Sensor (located on top of the rear diff) Maybe try pull it out an wiping it off with a clean rag. Sometimes it gets gunk on it and messes things up.
Also make sure your fluid is clean, filter is good, proper amount of fluid?
Have you been able to check for trouble codes? That will go a long way in determining what the problem might be.
If you're getting a P0500 (Vehicle Speed Sensor Malfunction) you might need to replace the VSS to correct the problem. Have the code(s) cleared after you fix the problem.
