Modular V10 (6.8l)
Replace exhaust studs before problem?
Old Nov 28, 2009 | 11:01 AM
tophog's Avatar
tophog
So I've now learned about the infamous exhaust manifold stud problem and just bought a 2005 V-10 with 49K miles on it. Looked at them last night and they all appear to be intact and the studs don't look rusted yet but most of the nuts are. Not sure how long I'll own the truck as I usually don't have rigs more than 3 years. Should I just drive it or replace the studs/nuts now while they appear to be in decent shape? I'm in Oregon so not rust-belt issues here ...just lots of rain.
Old Nov 28, 2009 | 11:18 AM
ol'yeller's Avatar
ol'yeller
If it ain't broke, don't fix it. Right now you have no poblem. If you take it apart, some studs will probably break in the head even if they look good externally now. When they do break, the truck is still drivable so why go through the pain and expense before you have to? I vote, leave it alone until you have to mess with it.
Old Nov 28, 2009 | 11:24 AM
tophog's Avatar
tophog
10-4. Thanks, I feel better when you put it that way I've always been a proactive person and have spent lots of $$$ as a result of my analism
Old Nov 29, 2009 | 04:04 PM
saggys's Avatar
saggys
I have had one broke for 2 years now and still no noticable leaks. I am thinking about installing headers and fixing the broken stud. We will see how good the tax man is this year.....
Old Nov 29, 2009 | 04:09 PM
joe chevy's Avatar
joe chevy
FYI if you didn't already know
studs available plain or extra expensive stainless steel
the SS is fords fix for this common problem
Old Nov 29, 2009 | 04:23 PM
dkf's Avatar
dkf
Stainless studs do not fix the problem. I had stainless studs on mine and one was broke even with around 20k on it. I put headers on because I wanted them and so I wouldn't have to deal with broken studs.
Old Nov 29, 2009 | 06:50 PM
Rugby3's Avatar
Rugby3
If you only keep rigs for three years I wouldn't bother with them at all. I had some broken studs going on five years before I decided to mess with mine. Since I waited that long it is probably the reason the heads need to be pulled and go to a machine shop to be removed. However even with many of them broken the truck ran fine, I just couldn't take the ticking noise and also wanted to go the new exhaust system route.
Old Nov 29, 2009 | 09:49 PM
BareBones's Avatar
BareBones
Its my understanding that the 2005+ V10's have stainless anyway. Must not fix the problem....
Old Nov 30, 2009 | 08:48 AM
dkf's Avatar
dkf
The problem is they got a real thick heavy manifold that gets really friggin hot. When it heats up it expands, when it cools down it contracts. Go through those heat cool cycles a thousand times and its darn hard on those little studs.
Old Nov 30, 2009 | 09:10 AM
tophog's Avatar
tophog
The nuts on my 2005 studs are pretty rusty ...
Old Nov 30, 2009 | 12:50 PM
dkf's Avatar
dkf
On my 04' the studs were stainless but the nuts were not, or were made of lesser quality stainless that rusted. The nuts look like they are powdered metal.
Old Nov 30, 2009 | 05:12 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Even my '01 had stainless studs.
The problem is, the exhaust manifold heats up and expands, and contracts when it cools.
When the nuts rust to the manifold, the manifold drags the nuts around with it as it heats and cools. This fatigues the studs and they eventually break.
Stainless would normally be better at moving around quite a bit before breaking, but it still happens.
The "solution" was to copper-plate the nuts so they didn't stick to the manifolds. I don't think this really solved the problem.
With the 2005+ 3-valvers, the manifolds are more of a "header" design instead of a "log" so the manifold doesn't push the studs around as much. So, the 2005+ has less problems with studs than the 2-valvers.
It does still happen though, we had one guy on here saying it happened to him.
I suspect it's a bigger problem in the "rust belt" than other areas.
JMG1
Nov 13, 2013 03:33 AM
spkennyva
18
Jun 2, 2012 09:42 PM
doctor_ratz
Feb 10, 2009 05:13 PM
wildboar12
1978 - 1996 Big Bronco
Nov 7, 2005 02:25 PM
BEAVER
Aug 22, 2002 05:49 AM
