AC FAN BELT
Old Nov 27, 2009 | 09:54 AM
backdraft341's Avatar
backdraft341
AC FAN BELT
i have a 1986 f150 with a 302. my question is can you get the belt for the ac to tight? i get a vibration sound at a certin rpm only under load not while idleing. it seems to be coming from ac compressor.
Old Nov 27, 2009 | 09:59 AM
Franklin2's Avatar
Franklin2
Only thing I can suggest is take the belt off and try it, and with the belt off you can check the bearing in the A/C clutch. If you need just the clutch, you can rent a special tool to pull it off and put the new one on.
