Limited slip friction modifier in power steering pump to make it quiet??
Anyone ever hear about using a small amount of limited slip differential friction modifier in power steering fluid to make the power steering pump more quiet??
Has anyone on this forum tried doing this?? If so-what were the results??
What kinda fluid do you have in the pump now?
Power steering fluid or trans fluid?
If its full of power steering fluid drain it out, pull the return line off and let it pump it all out. Then fill it with tranny fluid, try it once you just might be pleasantly surprised by the result.
it has saved 3 leaking racks and 4 noisy pumps.
i like the lucas trans fluid also.
never tried lucas oil additive so i have no knowledge of it.
1L243
04-11-2017 07:58 AM
bustedflush
15
09-07-2007 03:02 AM
aplustechnician
17
12-09-2005 01:01 PM
