Winter projects?
Old 12-03-2009, 12:40 PM
FORD RANGER's Avatar
FORD RANGER
FORD RANGER is offline
hell don,
thats even better.
hi allen.
  #32
Old 12-03-2009, 04:30 PM
Old93junk's Avatar
Old93junk
Old93junk is offline
Yeah, finish up that project, Don!.............So you can assist us with ours!
  #33
Old 12-03-2009, 05:05 PM
bertha66's Avatar
bertha66
bertha66 is offline
Originally Posted by FORD RANGER
hell don,
thats even better.
hi allen.
Hello Jack, hows the vally weather treating you?
  #34
Old 12-03-2009, 06:01 PM
FORD RANGER
i'm good allen.
and thanx.......
  #35
Old 12-03-2009, 10:07 PM
Old93junk's Avatar
Old93junk
22 degrees over here this morning......................puts the "winter" in winter projects!
  #36
Old 12-04-2009, 11:15 AM
bertha66's Avatar
bertha66
bertha66 is offline
I know, 17 degrees this morning, poor old Taraus was hard to deice.
  #37
Old 12-04-2009, 11:25 AM
fabmandelux's Avatar
fabmandelux
fabmandelux is offline
20 deg here this morning, brrrrrrrrr! Now up to 33 deg and bright sunshine. I want summer back!
  #38
Old 12-06-2009, 09:08 PM
Old93junk's Avatar
Old93junk
Started tearing down the 2.3 yesterday................Pretty good ridge on the top of cylinders, went to AZ to rent a ridge reamer..............It was screwed up by the last person to use it and now have take it back, 40 mile round trip............Grrrrrrr!......Cant take the pistons out thru the bottom, only the top on a 2.3 OHC.........I hate setbacks!
  #39
Old 12-06-2009, 10:37 PM
FORD RANGER
you can borrow mine dave.. here a few years back i replaced the bit in mine and haven't used it since. and its a blue point. the last time i used it it was on my race car engine i built. it was a 82 318 w/360 aawj 4v heads. comp cams extreme energy cam, variable duration lifters, and push rods. that engine is in my 68 coronet today.. that car and engine has 7000laps on it and she is tired.
  #40
Old 12-07-2009, 12:34 AM
46yblock's Avatar
46yblock
46yblock is offline
Winter
I am waiting on heads from the shop to put on the 64. The truck isnt vey good but engine is. Great block with new pistons and 60 psi oil pressure. The tear down was tough with only the left arm, as the other is out of service due to shoulder surgery. My wife always tells me one way to build brain function is to do things in an unaccustomed manner. I should be getting real smart. Most all the time taking the engine stuff off was spent inside the motor compartment. Had to use the engine hoist to take off intake and heads. Shoulder has been hurting this week due to too much usage.
While waiting for the heads tore down a newly acquired 312 the last two days. The block is shot, but...G heads with seats installed in intake and exhaust, positve seal valve seals, new vavle guides, hardened valve keepers, great crank. Just couldnt believe it. and other goodies.
It has been interesting doing all this in a disabled state. You use knees, stomach, just about anything available to get the job done. Took out a couple valves using my chest to compress the valve spring compressor.
Maybe winter is good, because there would be a whole lot of more boring things to be done.
  #41
Old 12-07-2009, 11:29 AM
fabmandelux
Good score on the 312! Keep your eye out for another 312 crank, my son want's to build another one.
You do know that you DON'T want to use a 312 block to make a 312 don't ya?
  #42
Old 12-07-2009, 11:57 AM
bertha66's Avatar
bertha66
bertha66 is offline
Well my window project took a set back yesterday, I broke the mounting for the wing window as I was reinstalling the wing window back into it's frame. With all the spare parts that I have, I have no more driver side wing windows left.
  #43
Old 12-07-2009, 12:23 PM
46yblock's Avatar
46yblock
46yblock is offline
Yes, I wasnt interested in the block anyway, but everything else. I am going to sell this crank to help pay for the head rebuild. There is a new grind 292/ 312 crank on the shelf. This looks like a great 10/10 crank. Do not think the rod journals need reground. An outfit in Eugene does a fantastic job of taking the mains to 292 size. They can even grind down the rear seal area while maintaining oil slinger.
  #44
Old 12-07-2009, 01:48 PM
Old93junk's Avatar
Old93junk
Thanks, Jack!........But I am gonna make AZ cough up a good one first, after all I only got 4 cylinders to ream the ridge off.........Still, what a PITA.
  #45
Old 12-07-2009, 04:19 PM
FORD RANGER
i will ship the tool to you dave and you use it and ship it back here. return shipping that is...
Quick Reply: Winter projects?
