Help, it is not starting
Old Nov 26, 2009 | 04:36 PM
devl3_74's Avatar
devl3_74
I have an 85 f250 with a 460. The other day it stalled in the driveway. I checked to make sure it had gas. It cranks but the engine just doesn't turn over. I replaced the carb inlet fuel filter. It gets gas, I am confused. please help me and let me kno what other things i should check.
Old Nov 26, 2009 | 05:43 PM
newrider3's Avatar
newrider3
Does it have spark? Is it getting air? Is there paper in it?
Old Nov 29, 2009 | 07:56 PM
devl3_74's Avatar
devl3_74
I just changed the spark plugs, new wires, new distributor cap and rotor. She still won't turn over. I followed the firing diagram from chiltons. I am going to have to go thru the process again to make sure all wires have been hooked up rite.
Old Nov 29, 2009 | 08:22 PM
newrider3's Avatar
newrider3
By "it doesn't turn over" you mean it isn't starting up and running, correct?
Not "turning over" implies that the motor is seized, or the starter isn't spinning, fyi. Different animal altogether than "not starting".
Old Nov 29, 2009 | 09:28 PM
Kuskoal's Avatar
Kuskoal
sounds like the spark box or the coil died. id start with the spark box, wither take one from a junkyard to see if it was dead, or buy a motocraft one, the cheaper ones from autozone dont do well
